CS250-S or CS350-LS center for LS-50 front?
tsaisz
Recently I had a chance to get a pair of cherrywood LS-50. Am really impressed by their clear, dynamic sound. But now my old center channel couldnt keep up with them. Did some research, knowing that CS400(i) or CS350-LS might be good match for them. But CS400 is too big for my cabinet, and CS350-LS is kinda out of my budget range (at least $150 in good used cond.) My question is: if I can get a CS250-S in half of price of CS350, will I regret it? I live in an apartment which is not that big. Just want to know if anyone has paired CS250 with LS50 before and how did they match?
Thanks for your help. This is my first post and I like this forum very much. Cheers.
Post edited by tsaisz on
Welcome to the Club!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I haven't heard the CS250 (S or otherwise). I've heard the LS50s with a CS400i and it's pretty darned good, the 350LS should be even better. If the 250S matches the line (and I think it does), it will probably do a fine job as a match. If it's like the current center lines, CSi, the smaller center (CSiA4) lacks bottom and depth in male voices compared to the larger (CSiA6), but dialog is crisp and clean...should be somewhat similar I'd think.Recently I had a chance to get a pair of cherrywood LS-50. Am really impressed by their clear, dynamic sound. But now my old center channel couldnt keep up with them. Did some research, knowing that CS400(i) or CS350-LS might be good match for them. But CS400 is too big for my cabinet, and CS350-LS is kinda out of my budget range (at least $150 in good used cond.) My question is: if I can get a CS250-S in half of price of CS350, will I regret it? I live in an apartment which is not that big. Just want to know if anyone has paired CS250 with LS50 before and how did they match?
Welcome to CP
EDIT: I spoke to soon. I looked it up. The CS250S uses a different tweeter. You will want at least a CS275 or the CS350LS. Each uses the Silver Trilam.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Thanks Ron, I got myself a CS350-LS now waiting for it to arrive. Just figured should take the best one I can afford than sitting there thinking what ifs....
I agree...nice center from all reports.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
The 350 is a great center, so nice choice! It will match your LS50s great and welcome to the club.
LS owners are coming out of the woodwork huh Ron!
Congrats on the LS50's tsaisz. I recently purchased a set of LS90's and I absolutely love them. I too have a CS350 LS on the way so we can compare notes along the way.
Welcome!-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
350 works very nice with the 50's..both share the same drivers, works great with the 90's too
