craigslist purchase sub + lsi9
edited September 2009 in 2 Channel Audio
I just bought an M&K v125 sub woofer from craigs list to augment my lsi9's and I am stunned. I can not believe how good my 2.1 system sounds now. I am floored. I was running them with out a sub before. Wow! Sub is in almost mint condition and I paid 125$ for it-just for fyi.
Post edited by ctrulock on
Welcome!
    Congrats!!!! Nice grab.
    Awesome 2.1... great craigslist deal.
    MK subs are great -- I guess more of a 'music sub' by today's insane standards of what a HT sub should do, but they are very good.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
    I had the same experience, a sub really opened up the 9's. Great pick-up
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
    Congrats-Mk makes great subs!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    Congrats. M&K subs are excellent. Where do you have your x-over dialed to? I think I had mine pretty low running the LSi9 and a sub.
    65 hz is where I think they seem the best in my small room.
    Just a humble opinion, but I have been going back and forth on two settings, 120hz for music and 70hz for movies. Seems to maximize the experience for me at least.
    Mains - LSi9's
    Center - LSiC
    AVR - Onkyo 706
    I am still tinkering a lot so I might try out a higher cross in a bit. Just wondering about the directionality of 120hz? What frequency is the highest non-directional?
    ct,
    Yeah, mine was pretty low too. I think I had it around 50Hz or so.
    dorourke07,
    What are you powering them with? The LSi9 should be fairly flat from 60 to 120Hz, so sub integration should be low. I think I had the same problem as you when I was blending in the sub w/9's. I found a different spot which made the mid-bass suddenly come alive. Try moving them forward and back to find a good spot where the bass is even. Did you play around with the phase setting on your sub?
    right now they are only bi-amped with an onkyo 706, not the ideal situation power wise. They are tightly flanked by the tv and bookshelves, which I think chokes them a little. I have a ML abyss at 180 degrees and haven't played with the phased setting. I have not made a lot of adjustments as I have gotten started with this process, I have been trying to really just get a grasp of what I am hearing at each step. I left the sub alone after my neighbor didn't notice it in the corner and commented on how good the speakers were and that it didn't makes sense to waste money on adding a sub.
    Mains - LSi9's
    Center - LSiC
    AVR - Onkyo 706
    Organ, I really do mostly music listen with the setup and was wondering your opinion on how to better power the LSI9's. They have a great soundstage in my room and maybe f power is making them more affective with the sub's support.
    Mains - LSi9's
    Center - LSiC
    AVR - Onkyo 706
    I find that a good start (and less$) for good power on the 9's are used 2ch integrated amps. They can be had for a couple hundred. You can get a seperate 2ch amp and use your receiver as a pre-amp (that is if your receiver has pre-outs). You will get more power and dynamics but you're also keeping the sound signature of the receiver's pre section.
    So a used integrated is a good place to start. But playing around with speaker placement can provide a big increase in performance too. Try bringing them well away from the front wall. Try the 1/3rd or 1/5th rule. What you'd want to do is bring them 1/3rd of the way into the room. This is too much for a lot of people and they end up going 1/5th. This type of set up usually minimizes standing waves and should even out the bass. My guess right now is that the Onk is not providing enough oomph in the bass and upper bass region.
    When I had my 9's, I went from an Onk receiver to NAD seperates. I was able to enjoy this set up without a sub. Of course, bass extension was missing after about 50Hz but the bass that the LSi9's could produce is mind boggling.
    For the phase control. Have somebody play around with the switch while you're listening to bass heavy music. Listen for more pronounced and depper bass.
    congrats and nice price
    front: rti8
    center: csi5
    surround: fxi3
    sub: eD a2-300
    receiver: onkyo 805
    ps3
    I have a pair of 9's in a 2.1 set up and find that I need to set the crossover to 100-120Hz for music (except for daytime rock when the wife is not around), and at 80Hz for movies. It may be that I have too much external power, but the bass in the 100hz range from the 9's is like someone is pounding the floor with a rubber mallet. The sub will get the bass a bit lower and I can controll exactly how I want the bass to sound.
    pop
    media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
    living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
Welcome!
Welcome!
