Biwiring and Subwoofer hookup
jaychevel
I have a pair of Monitor 70's and CSI5 as my front channels which I have biwired. They sound great compared with when I originally had them single wired. They just sound more crisp.
I have a Velodyne woofer that I have hooked up through my Onkyo SR-604 with a "y" wire in to the LFE input. My woofer in not activated in stereo or game mode, only surround mode. How do I hook up my Monitors 70's by speaker level, which speaker pins do I use? Currently I have wired them from my Onkyo to my Monitor70's. I would like to run a wire from the woofer to the Monitor 70's, to decrease distortion,if that is appropriate.
Appreciate any help
Polkie-jaychevel
Appreciate any help
Polkie-jaychevel
Post edited by jaychevel on
You run a pair of speaker cables from the Onkyo to the Velodyne, then the bi-wires from the Velodyne to the Monitors. It sounds like you're trying to use both LFE and speaker level inputs which I don't think is possible.Hope his helps
