anyone heard of these? Advent+Sunfire Sub
Saw this for sale...ADVENT Sunfire Technologies AV550S Subwoofer.
Anyone heard of this and what it would be worth?
from the ad:
The Advent AV550S is the result of the only collaboration between BOB CARVER and Sunfire Technologies. If you're looking for low bass that shakes the floor, you're gonna love it. It has a 15" woofer and has about every type of input that you could think of including Rca, speaker, and LFE. It also has Gain, crossover, and phase controls to make the perfect sound for movies, video games and cds.
thanks for any input....
off to run some searches.....
from the ad:
Post edited by kcoc321 on
I used to have one. it was a low and loud sub. I sold it for a couple hundred in mint condition. The 15" does not move much though.
might be worth asking on www.carveraudio.com or www.thecarversite.com forumsPanasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Sunfire did provide amps for other audio companies over the years.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
thanks everyone.
The links to the AV Reviews pointed out that while the Sunfire amp is 250w RMS/ 500w peak, the box has some resonance issues that effect the proformance.
Searching the carver sites didn't turn up any info, bummer.
we'll have to see what I can get it for. -
thuffman03 wrote: »Sunfire did provide amps for other audio companies over the years.
+1
They did the same with Acoustic Research if you find any models that say they use some of their amps.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104Any clue how to use the internet? Found it in about 10 sec.
