Do i need more power?
packetjones
Hello all, I am looking to get some new towers and am curious if my HK254 will be enough for them. It is rated at 50w per channel but I have heard that HK's are known to rate power differently. I have my planned set up below and was curious if i would have any issues. Thanks for any info.
HK 254
pair of RTi A5's
pair of RTi A3's
CSi A4
PSW 110
HK 254
pair of RTi A5's
pair of RTi A3's
CSi A4
PSW 110
Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
Post edited by packetjones on
IMO: I would definitely look at an external amp. I don't know much, but 50watts per channel on those speakers that you have listed is very little power. Your receiver has pre-puts, I would look into some 3/5 channel amps.Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables -
Welcome to Club Polk Packet.
All speakers benefit from more power. Your HK has preamp outputs so that if you decide that you do want more power, you will just have to buy a separate amplifier to attach to the receiver.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
yeah like cfrizz' Sunfire Cinema Grand Signature 405wpc 5 ch. Amp.....thats a beast!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
i know that they would sound better with more power, but i am curious if my HK will be able to power them on its own. This is my first 5.1 HT and can not afford to get an amp at this time.
Should i not get the A5's? I know that with any of the other larger towers I would have issues but thought that the smaller A5's would be ok with my current AVR and the power it puts out.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Those are 50 real watts though, not "50" watts from cheap receivers.
For most people that would be enough, but if you want the best from your speakers I would give them much more power, like the sunfire that was recommended prior.^^Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
sure it will, just not very efficently, just be careful to not start clipping them.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I am going to buck the trend a little. That HK's 50w per ch will do a decent job at driving those speakers, which is not a difficult load at all. As others have said just about all speakers benefit from more power, specifically gobs of reserve power available for instantaneous short term peaks. As long as you are in an average size room with average listening levels, you will probably be happy.
As others have pointed out your HK has pre outs, so if you feel like you want more power, that option remains open to you but does not need to be rushed into. -
As you can see from my signature,I have a very similar speaker set up with A5 as my fronts and RTI6's (older version of the RTIA3's) for my rears. I am driving them with a powerful avr and they sound great. You won't be able to drive them like I am but you will be able to drive them with your avr. That said, I am going to purchase a power amp in the future and use my avr as a pre-pro. If you were to listen to my current set I think you would be pleased at what you hear. But were always looking to get more out of what we have. Take the advice of others in here and put more power to those speakers, you won't be dissappointed in the results.
Tim"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I also have the A5's and a csi A4 and was wondering about adding more power. My receiver putts out 90 watts to 7 channels and doesn't have pre outs. For me to get more power to them would cost around 1000$. Will the difference in sound be worth 1000$? or should I upgrade my surrounds to the fxi line instead.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
I ran my RTi A5's off a HK unit for a good while. It ran with zero problems and sounded really nice.
I later added an amp and the biggest jump in output was the noticeable bass increase. Highs got a little more tame but in the end the HK did a decent job on it's own.
Will a amp help them later on certainly but if your budget is tight i wouldn't worry about it too much for the time being.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
I appreciate all the additional responses. The first few responses made it sound like i would have to have an amp to enjoy the new speakers. I knwo that teh sub that i have is not the best but i got it opn the cheap $100. I work at best buy so i can get a good deal on all of these speakers.
Does anyone have any good recommnedations on budget amps if i find that i need one. I am thinking that a 2 or 3 channel amp should be sufficient.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
You can never have too much power.
I have owned 2 HK AVR's and they were rated at 35 and 65 wpc and I was never impressed with their power output. I do like listening to music at near concert levels so that most likely is why I have 500 wpc on my main 2 channel system.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
The HK 2xx is an excellent platform. It will drive the A5s without issue. I still use mine as a pre/pro, but prior to that I compared it to several quality entry to mid level AVRs from Onkyo, Pio and Denon and preferred the HK sound. There was no discernable lack of power, in fact the high capacitance of the HK gave it a cleaner an punchier sound than all of them (except the Denon 2307CI...though I still preferred the warmer HK). As stated the A5s aren't a load. They will improve with an amp, but the HK will sound very respectable.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
packetjones wrote: »I appreciate all the additional responses. The first few responses made it sound like i would have to have an amp to enjoy the new speakers. I knwo that teh sub that i have is not the best but i got it opn the cheap $100. I work at best buy so i can get a good deal on all of these speakers.
Audiosource amps, good price & under-rated. -
The first amp I added was an Audiosource Amp/One A. I bought it for $100 used. 80wpc X 2 and ran it on R50s and RTi8s, even my SDAs for a short time. It was a neutral, clean sounding amp and an improvement over the HK 2xx.Audiosource amps, good price & under-rated.
If you look in that direction, go with at least an Amp200 or 300. The Amp100 won't be enough of an upgrade.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron, I am using the Amp Three and Amp One right now. They are both neutral sounding, but the Amp Three has more headroom, as expected.
The Amp Three is the first version of the amp 310. It's far from an audiophile amp, but it's much, much better than most of the receiver's amp. It's very good value for the $.
A buddy brought over an Amp300 he bought off CL. We plugged it in here and I was surprised at how much bass and punch this amp had. It wasn't as defined as my TFM45, but it had plenty of balls. I think he paid $110 for it.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
