1040mm
carebear
whats up new guy here. im thinking about 2 mm1040 for the back of my tacoma, read some reviews and they all seem to be good. does anyone have these that maybe can give me some advise. also i want to get some component speakers and dont know where to start any advise would be great thanks
Post edited by carebear on
I run a single 12" mm and am very happy with it. I too have read good reviews on the 10" both here and on other forums. After all it's a polk
As for components, it would help if you could specify the budget as also the kind of sound youre looking for and the music you listen to. -
yo Arun can you tell us a little more about the MM sub your using. Sealed or ported setup? how does it compare with other similar subs you've tried/heard? (in terms of like SQ, output, and the lows)
CAREBEAR - if you decide to go with the MMs, please post your thoughts on em
