how long are you
sandworms
what would you guys feel comfortable with in spk wire distance. I want to wire my outdoor atriums and will probably need 2 runs of 100 feet or so. or i can mve my receiver if needed
Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
Post edited by sandworms on
I have my Atriums with close to that, maybe a little more. I used 14 g wire, and power them with an Adcom 535. Sounds pretty good._________________________________________________
I'd imagine you'd be fine with 100' runs. Shorter is better, but with an outdoor setup, it's not as critical. I'm guessing you won't be doing much critical listening on the Atriums anyway.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I ran 10ga wire to my Atrium 65's but I had extra wire so I just used it up.....I would think that 12 ga would be more than adequate for that run.
I am 8" longTV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3 -
My girth make up for my length.
I helped my Dad wire up his outdoors with 16g and they sound great. You won't need anything else.
Need higher gauge than 16: at 50 feet even the "wires don't matter" crowd will tell you that it starts to make a difference. I'd personally do 12, but 14 is probably ok.
Reference:
http://www.roger-russell.com/wire/wire.htmGallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I have 3 kids and my Wife is happy..so...........Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
