Harmony One Remote
ninerbj
ninerbj Posts: 870
edited September 2009 in Electronics
Buying a new plasma this weekend and want to replace my old wore out 600 series Harmony.
Does anyone here have the Harmony One? Is it really "the one"?
Would appreciate any feedback.
"she had the body of Venus, with arms."
Post edited by ninerbj on
  • Ricardo
    Ricardo Posts: 10,636
    I have one and love it. Had the 659 before (I think that's the number). Both do everything I need them to do, but I like the One better basically for two reasons:
    -Rechargeable
    -Layout (much more intituive IMO).
    SOPA
  • FittyFieFo
    FittyFieFo Posts: 482
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • bevo
    bevo Posts: 306
    I have the 670 and can't stand it. It is always forgetting which devices are turned on or off. I go to watch tv, and it forgets to turn on the cable box, tv, or DVR. It works right maybe 1 out of 5 times. Every time I use it I have to push the help button to fix things. Also I can't really use the volume function with my denon avr. If I push up it will go up like 10db. It's really hard to get it to work right with the volume.
    I am though one of the only people that seem to be having trouble with it, so maybe it's a user error and not the device's problem.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • thsmith
    thsmith Posts: 6,082
    yes, the H1 is the one
  • Willow
    Willow Posts: 11,231
    bevo wrote: »
    Nope, mine does this as well. When I want to switch to use the PS3 it always changes the TV input but rarely changes my HK to Vid3 :mad:
  • Sherardp
    Sherardp Posts: 8,038
    It is definitely the One. I have my setup to turn on Air Conditioning, BD player, PJ, AVR, dim lights to scene 4, when I come in HT room and press Watch Blu Ray. Works great.
  • jimmydep
    jimmydep Posts: 1,305
    I'm considering the Harmony One also. From all I've read it seems like it can do it all and then some.
    Sheradp, How do you get it to turn on the AC.???
    Jimmy
