Attention sda srs 1.2 owners!!!
michaeljhsda2
Owners of SDA SRS 1.2's should check the labels on the back of their speakers. If the label shows a blade/blade connection, and the + binding post nut is on the right and you have a pin/blade connection chances are your speakers are wired out of phase.
In order to confirm this remove the passive radiator and the crossover and make sure the black wire (+) on the back of the binding post is connected to + on the crossover.
Here is the link that addresses this situation.
http://www.polkaudio.com/forums/showthread.php?t=87728
Mike
Mike
SDA SRS 2.3TL's
SDA 2B TL's
SDA 2B TL's
