35+ foot hdmi cable
mdk5068
Looking for an hdmi cable that is at least 35 feet long. Price range under 50 (ideally significantly so). The hdmi cable I got recently broke (tip bent in the receiver because it was too small).
Thank you,
Mark
Thank you,
Mark
Bulls make money.
Bears make money.
Pigs get slaughtered.
You, my friend, are the bacon.
Bears make money.
Post edited by mdk5068 on
lol, yea I know, just figured I would give used and cheaper a try if possible. If I do resort to monoprice would it be best to go for a 22 or 24 awg wire? Is there a huge difference?Bulls make money.
Bears make money.
You, my friend, are the bacon. -
Given you need more than 15 ft., I would go with the Blue Jeans Cable HDMI: http://www.bluejeanscable.com/store/hdmi-cables/index.htm
If you want a premium HDMI cable, I would search ebay for the Wireworld Ultra-Violet.
mshan242700 wrote: »Given you need more than 15 ft., I would go with the Blue Jeans Cable HDMI: http://www.bluejeanscable.com/store/hdmi-cables/index.htm
awesome thanks! Does it really matter between 22 and 24 awg?Bulls make money.
Bears make money.
I have no idea.
Maybe contact Blue Jeans Cable and see what they think. -
My understanding from my video industry friend is that you're better off with component over that distance.
Have you tried HDMI over ethernet? There was a discussion thread about it in the clubhouse somewhere.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042501&p_id=5403&seq=1&format=2Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
For the length you want at 50.00 your screwed. ( of any quality). And if your going to go HDMI spend the money and get GOOD ones. Also check transfer rates. Sometimes that's the price diff.
