...i was looking for a htpc case then i see this
SivaNevets
SivaNevets Posts: 303
edited August 2009 in The Clubhouse
:eek:
49426f10db891
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Post edited by SivaNevets on
  • Face
    Face Posts: 14,340
    edited August 2009
    That's pretty wild.
  • Jstas
    Jstas Posts: 14,842
    edited August 2009
    That's actually a pretty nice case.
    http://www.gmc.co.kr/english/programs/read.php?board=PRODUCTS&uid=51&category=11&depth2=25
    Take a look at some of the "action shots" in the gallery though. Made me laugh.
    the only problem I have with it is that it only has room for two internal drives and only one optical drive. But, if you drop one of these in:
    http://www.amazon.com/Corsair-CMPSU-1000HX-1000-Watt-Professional-compatible/dp/B00154QAXQ%3FSubscriptionId%3D16330PR1NAHTNCZP5602%26tag%3Dpriwat-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB00154QAXQ
    and that could end up being a pretty spiffy gamer rig!
    And yes, I have an internal array in my home machine. I have 7 hard drives totaling 1.6TB so I use all of my internal and external bays. Yes, my system runs hot but there are 9 fans in the case, all of the them variable speed and the entire case is aluminum. Cooling has always been a problem.
    Expert Moron Extraordinaire
  • nadams
    nadams Posts: 5,877
    edited August 2009
    Fugly, if you ask me.
    Ludicrous gibs!
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2009
    Wow, that's pretty wild.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2009
    Check out Corsair, Xigmatek, Antec. Nice cases with allot of airflow for great cooling. I kinda like the case above, I tend to like different.
  • bruss
    bruss Posts: 1,039
    edited August 2009
    That power supply is the ****.. I use whatever case i can get and just mod it if i need more fans or airflow.. I would rather spend the coin on guts
  • SivaNevets
    edited August 2009
    but i endup getting these. nice little chasis, like the brushed aluminum (black)
    <object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/kyacOc7JyFs&hl=zh_CN&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/kyacOc7JyFs&hl=zh_CN&fs=1&&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited August 2009
    I don't particularly like that case either :o
    i do however like my Antec FUSION remote MAX! :D
    http://www.antec.com/Believe_it/product.php?id=NzE0
    The pictures do it NO justice! the thing is beautifull IMO and matche's VERY nicely with my yamaha AVR :)
    Now if i could only get the stupid 8 pin extension cable here i could fire this thing up and enjoy my new HTPC :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Face
    Face Posts: 14,340
    edited August 2009
    I have the same case, I love it.
    Yours looks empty in comparison though. :D
  • sTiLlLeArNiNg
    edited August 2009
    A modular PSU with some cut n' chop extension's and a lil' wire management with a stock CPU cooler make a BIG difference! lol I'm a bit anal when it come's to wiring in my PC's :o
    here's a pic of my Liquid cooled P4 on it's side while i was bleeding the loop and another of the backside:
    How do you like that coolermaster HSF and what are you packin' in that sucker? :D
    I'm thinking of getting a TRUE 120 later on down the road :)
    Media Room 7.1
    HTPC
  • Face
    Face Posts: 14,340
    edited August 2009
    That's actually a Coolmaster V10. http://www.coolermaster-usa.com/product.php?category_id=1623&product_id=2880
    I had to trim the front of it with a belt sander so it would fit in the case. And if it wasn't for the low profile sound card, there would be no way it would fit. If I were to do it over again, I would probably go with water cooling though.
    The rest of the rig is as follows:
    i7 920
    6 gigs of OCZ Gold DDR3
    P6T Deluxe mobo
    NVidia 260 Black Edition
    1.25 TB of HD space
    PC Power and Cooling Silencer 750(upgrading soon)
    ASUS Xonar HD AV1.3 sound card
    Coolmaster V10 Hybrid CPU cooler
    Antek Fushion Max HTPC case
    Blu Ray drive
    MX-518 mouse
    Saitek Eclipse keyboard with LED backlit keys
    I'm still running XP though. I bought another HD for W7, but it won't install on it. The installer will only let me install it on my C drive, which is nearly full. :rolleyes:
  • sTiLlLeArNiNg
    edited August 2009
    SWEET rig you got there! :D the new intel stuff was/is to pricey for me right now so i went the more basic route :o
    Man that coolermaster is HUGE! :D since i went with a more basic CPU i think i should be OK with the stock HSF for now and i decided to get a nice Thermalright HR-03 for my GFX card since it will be doing most of the work ;)
    You're running the Lo-Pro model Xonar? How do you like the sound quality? I got the standard height one and it's HUGE for a soundcard! even has it's own molex connector! :eek:
    I suck with the programming stuff so i think after i get it all assembled i'll take it in and have the tech set it all up for me, i'd like to dual boot Xp & VISTA :)
    Media Room 7.1
    HTPC
  • Face
    Face Posts: 14,340
    edited August 2009
    It's different than the Xtreme Music that it replaced.
    Even though I'm using the digital coax to feed my DAC and they claim there is no processing in the mode I'm using, it sounds sharper. It makes me wonder about the creative card that it replaced. It also has a LOT more gain, which helps me since I'm running a passive preamp, but can make adjusting the volume a little twitchy at times. Due to it's additional "sharpness", I'm going to have to make a couple of subtle changes in the rest of my rig.
    I would skip Vista and just go for Windows 7.
  • polrbehr
    polrbehr Posts: 2,834
    edited August 2009
    Face wrote: »
    Big surprise there... :D
  • Face
    Face Posts: 14,340
    edited August 2009
    Hey, there's a first for everything. :D
  • sTiLlLeArNiNg
    edited August 2009
    Face wrote: »
    Xonar is DEFINATELY a MUCH better choice than Creative poo-poo! Anything Creative before X-fi was/is decent but now they suck :( I'll be using the HDMI on mine and can't wait to hear it perform :D
    I have Xp & Vista on hand so i'll use Xp for some older game's that i still like to play every so often and Vista will be for the built in MCE and newer game's i'd like to get ;) I also have a thing with using Virgin OS' :eek: let someone else pop the cherries :p i'll upgrade if/when i need to or 7 is tried + true :)
    What are you thinking of upgrading?
    Media Room 7.1
    HTPC
  • Sherardp
    edited August 2009
    I just bought a Xonar D2 card and it is simply an amazing card for SQ. It is night and day difference from Mobo chipset sound also. I bought PCI version which is the D2 and it installed no problems. Highly recommended. Also nice cases and install gents.
  • sTiLlLeArNiNg
    edited August 2009
    good to hear of another satisfied Xonar customer! ALL of the Xonar line-up are GREAT card's IMHO :)
    Thank's Sherardp :)
    Media Room 7.1
    HTPC
  • SivaNevets
    edited August 2009
    i found Azuentech X- FiForte / Prelude are also tobe equally great choices for HTPC.
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
