bi amping question
maandjojo
maandjojo Posts: 293
edited August 2009 in Vintage Speakers
Thinking of using a pair of Adcom 545s' at 100 w per instead of one 555 at 200 w per.
I know you would hook up the left speaker terminals of the amp to the upper and lower connections to the speakers and the same with the right connections. I am using the preouts from a receiver, so the question would be how to hook up the inputs from the each of the amps. Would I just use a y connector from each left and right and send it to the preouts.
The amps will be used for my 2.3tls', by biamping I think I would get more out of (2) 100 watt amps than just (1) 200 watt amps. Would I be correct?
Thanks,
Joe
Joe
Post edited by maandjojo on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2009
    There are a lot of "depends" in there, but you won't know until you try it in your system....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2009
    Isn't the point of bi-amping to use an OUTBOARD crossover? One amp gets the low-frequency signal, one amp gets the high-frequency signal?
    Sounds to me like you're doing something akin to bi-WIRING; which in my opinion is a complete waste of time, money, effort, and enthusiasm.
    First Guess: You're going to lose ultimate volume potential by reducing the amp power.
    Second Guess: You're not likely to use the ultimate volume potential anyway.
  • thuffman03
    thuffman03 Posts: 1,325
    edited August 2009
    If I had to choose I would go with one larger amp over two smaller amps. I just feel that at lower volume you will get better sound because the single larger amp has more power in reserve. I think it will be a push at high volumes.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    maand. don't waste your time. get the GFA-555. what your describing is passive bi-amping, which in turn has minimal benefits.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • Deadof_knight
    Deadof_knight Posts: 980
    edited August 2009
    get your stroke on and buy 2 555's
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Systems
    Systems Posts: 14,872
    edited August 2009
    Shicks18 wrote: »
    Agreed I don't think there is much to gain passive bi-amping with the 2 545's vs a single 555.The real gains to be had are when you remove the passive xover and actively bi amp.
    Testing
    Testing
    Testing
