just realized RTIa7 and RTIa9 use same bass woofer as PSW10
SivaNevets
SivaNevets Posts: 303
edited August 2009 in Speakers
1 - 10" Diameter (25.40cm)
Dynamic Balance Polymer Composite cones
2/3 - 7" Diameter (17.78cm)
Polymer Composite with Rubber Surround
they didnt mention the word 'rubber surround' to psw10 :p
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Post edited by SivaNevets on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2009
    Don't think they're the same
  • SivaNevets
    edited August 2009
    at least the same material?:confused:
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • BjornB17
    BjornB17 Posts: 752
    edited August 2009
    Not even close.
    1) Different size
    2) Different materials (foam surround on PSW10)
    3) If you see them in person you can tell they are not even related to one another and look considerably different. Woofers on the RTi series look much nicer.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited August 2009
    Aside from the cones being made of similar materials...they're completely different woofers.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • leroyjr1
    edited August 2009
    Both are grey, and made by Polk sooooooo yeah they're similar.
