How Far????
Johnnybass
I need help on this one. How far should the front speckers be from the Recever??? There Polk tsi300's with a tx303 avr.
Thank you john
Thank you john
Post edited by Johnnybass on
That all depends how big your room is, your layout, etc. There are many variables that should be considered when trying to figure out speaker placement. Try keeping your fronts and center on the same horizontal plane though so neither one stands out when watching movies if you have an HT setup going.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
as far? in terms of what? there is no issue with having the receiver far from the speakers.
yep..what they said....most AVR manuals will give you an idea of general speaker placement....good place to start.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
"You want to create an equilateral triangle between your speakers and your listening position, toe in for personal preference" " per the manual.
So same distance from your ears to the speakers and the distance between the speakers.
