Alesis ra-150
Pauly
Pauly Posts: 4,519
edited August 2009 in Electronics
Never heard of these amps. Didnt find much no CP about these. Worth 100 bucks?
Pauly
Life without music would
Post edited by Pauly on
  • unc2701
    unc2701 Posts: 3,587
    edited August 2009
    Probably not. It's a not a home audio amp & it's got a fan in it which is going to annoy you. I'd get an Adcom 535 instead. More wattage, no fan, about the same price.
    Backburner:Krell KAV-300i
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited August 2009
    unc2701 wrote: »
    Where did you get that it has a fan in it?
    From the product page:
    Cool, quiet operation.
    Designed for studio use, each RA series amp incorporates advanced convection cooling for heat dissipation. The result is long, stable operation unaffected by heat-related complications, without the added distraction and annoyance of fan cooling. And eliminating the danger of losing hard-to- hear details due to noisy amp performance.
    http://www.alesis.com/ra150
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2009
    I think you're right Less, I kinda remember in the Manny's(NYC) catalogs I used to get, they advertized the Alesis amps as a being good amp for a recording studio. And of course the had the Alesis Monitors also.
  • engtaz
    engtaz Posts: 7,669
    edited August 2009
    Looks like a Behringer A500.
    engtaz
  • LessisNevermore
    edited August 2009
    Polkie2009 wrote: »
    I've heard an older Alesis amp, don't recall the model, (100wpc) it was very neutral sounding, and very clean. Very desirable traits for a studio amp. It would make a great base for a bedroom/small room system.
