Subwoofer
nileriver23
I am looking to buy a subwoofer. The absolute max that I would spend is $400. I am not really looking for anything in particular, just something that is good lol.
Thanks.
Thanks.
Post edited by nileriver23 on
If you live close to Pittsburgh PA I would suggest checking out the Vintage HiFI shop I buy a lot from. www.vintagehifishop.com
I don't see anything listed but if you give him a call I am sure he has something that would fit your needs.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Check out this Paradigm subwoofer:
http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1256247202&/Paradigm-PDR-10-SubwooferLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
