subwoofer help
dvd_rw
dvd_rw Posts: 7
edited August 2009 in Speakers
Hi, I have the Tsi500 and I am looking for a good sub in the range of 500-600. I was trying to choose between the martin logan abyss and the avs123 MFW-15. Can anyone suggest which one is better or toher subs which can be better. The only thing about the MFW-15 is that they weigh about 120 lbs.
Thanks,
dvd
Post edited by dvd_rw on
  • thuffman03
    thuffman03 Posts: 1,325
    edited August 2009
    If you want a lighter smaller sub that hammers very hard then you should look at a Sunfire True Sub. They have been selling on Ebay in your price range.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • thsmith
    thsmith Posts: 6,082
    edited August 2009
    I think before you should receive suggestions first provide your room cubic feet including any large openings and what you are trying to do with the sub, music and HT, just HT or just music.
  • dorourke07
    dorourke07 Posts: 298
    edited August 2009
    In my 14x20 room my ML abyss IMO does a fantastic job with music and is plenty for HT.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • danz1906
    danz1906 Posts: 5,144
    edited August 2009
    Try one of the SVS subs.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • apphd
    apphd Posts: 1,514
    edited August 2009
    thsmith wrote: »
    This can not be stressed enough! The size of your room W x L x H + openings, and the subs intended use, HT/music/both are VERY important on selecting a sub that will please rather than disappoint you. Your budget should allow you to find something good for the average small to medium sized room. There are many good subs out there, when you determine what you need, all the mainstream manufactures have one that will do it. You then just need to find one that will do it in your price range. Don't forget used, but try to find one local as most are HEAVY and shipping can be a pain and add to the cost.
    When you have the choices narrowed down a little research the companies to be sure you feel comfortable dealing with them.
    If you are set on the ML or the MFW you mentioned in the OP then I would say go with the ML.
    Besides the subs mentioned by others above, look at HSU, Elemental Designs, Outlaw Audio, to name a few.
  • dvd_rw
    dvd_rw Posts: 7
    edited August 2009
    Thanks for the replies. My room is about 15x25x15 and I will be using it for 30 % home theater and 70 % music . I am looking for a crispier accurate base rather than the boomy.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    Boominess comes from a cabinet that is too small for the driver/amp, and also little lining and stuffing inside the cabinet.
    Look for a sub with a larger cabinet; ported subs are also a good choice.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    Shicks18 wrote: »
    +1
    Id somewhat agree with Shicks as hes on the right track, the "boomy" type bass usually comes from subs that are on the rather 'weak' side, and are often enclosed in a large box to give you an artificial type bass which compensates for their lack of power.
    Id say check out www.epiksubwoofers.com they have a wide variety there that'll certainly please. Svs have a very thunderous bass and are better recommended for HT, but the 'variable tuning' models (that let you seal a port or 2) give you slightly tighter/accurate bass for music. Go audition some subs, best thing to do imo and just let your ears be the judge.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • BB3
    BB3 Posts: 297
    edited August 2009
    thuffman03 wrote: »
    dvd_rw,
    thuffman03 is giving you excellent advice, I couldn't agree more.
    The Sunfire is flat out devastating and you can that to the bank.
    Take Care dvd_rw. I hope you get exactly what you want.
    BB3
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Sonic Frontiers SFCD-1
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    2-Carver Silver 7-T's
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio SDA-SRS 1.2TL
    PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • SivaNevets
    SivaNevets Posts: 303
    edited August 2009
    check out refurbished Polk DSW Micro 1000 from ebay direct
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • apphd
    apphd Posts: 1,514
    edited August 2009
    dvd_rw wrote: »
    "I will be using it for 30 % home theater and 70 % music. I am looking for a crispier accurate base rather than the boomy." With this I would say the ML all day any day, especially if you can find one <$600.
    But (that word that always kicks us in the butt with this hobby) that room is huge:eek: That 15' ceiling is going to suck up a lot of output. You can give the ML a try and see if it performs satisfactory for you. If not at least you will have an idea what you need, and IMO I think you could resell the ML at less of a loss than the MFW.
    I really have my doubts as to whether 1 or even 2 of the ML (which is a really nice sub) can get the job done in that room. You probably will need some of the sub manufacturers mentioned above or something more like this:
    JL Audio F113
    or Epik Conquest
    eD A7s-650
    Sorry I know those are way over your budget but IMHO that is what it is going to take in a room that size.
  • vijayl
    vijayl Posts: 258
    edited August 2009
    My room is worse abt 35x15x18 (vaulted ceiling starting at 12' on one end to ~18' on the other end). I had 2 fronts w/ built in SWs and it was not enuf to fill the room. Now I added one ML Dynamo which gave enuf Bass. Now running 3 SWs (2 Def Tech Mythos powering 250W each and ML with 200W).
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • apphd
    apphd Posts: 1,514
    edited August 2009
    vijayl wrote: »
    vijal
    Is everything pretty much close to your seating? That is another huge room (to me) makes for a very challanging job buying and setting things up.
    Is that really getting it done, or just made it acceptable? I have heard good things about the SQ of the Mythos, and the Dynamo is again a good little performer but that is a huge room.....room.......room....ro:p
  • vijayl
    vijayl Posts: 258
    edited August 2009
    apphd, these are 13 - 15' away inline with the TV in the front stage.
    Now just to give more details, I hear very good bass from kitchen, which is adjacent to my living room. With my current setup, I egt a good bass, but not boomy. Good enuf punch that I enjoy both music and Movies..
    , logitech 880
