Break in period for new speakers?
mordir1297
I just purchased a pair of TSI 500s, a CS20 and a some surrounds. Do the speakers need a break in period or are they ready to rock the moment I take them out of the packaging? If they require a break in what is the minimum time I should let them break in? What should I break them in with?
Post edited by mordir1297 on
They don't have to be broken in before being used for the application they were intended for. But, they will some best with some time on them.
To speed up the process, you can let them play for a few days while you're doing other things around the house."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
do all speaker's require a "break in" period? anything in particular should be done or just let 'em play at moderate/low volume?Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask -
All speakers go through some sort of break in period. Nothing special is needed to be done, just play them as you normally would."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Just enjoy them dude. To be honest? Most folks won't even notice a break in period and the associated changes. You have to be hardcore for that. Even if you are semi-hardcore, just enjoy them and don't worry about the break in. It'll come. No sense in wasting time not listening to the music.
Welcome to the forum BTW.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I hate that edit and record edit within 2 minute BS. First one I've had in around a year or so. :mad:
Just sayin'...........
To the OP, this has nothing to do with your post. Carry on.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
well i have always "burned in" in my PC's before OC'ing and always broke in my nitro RC's prior to leaning them out so i don't mind the processMedia Room 7.1
HTPC
Most of what I read about breakin would be around 100 hours of above average volume levels. Now that could me more or less depending who is doing the playing. But I have heard a difference around 100ish hours or so.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
100-200hrs for break-inLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I use this for what I drive!
But for speakers, I go full throttle on day 1. Or I guess you could say listen to them like you stole them.
For the first 500 miles/805 km:
• Avoid full throttle starts and abrupt stops.
• Do not exceed 4,000 engine rpm.
• Avoid driving at any one constant speed, fast or
slow, including the use of cruise control.
• Avoid downshifting to brake or slow the vehicle
when the engine speed will exceed 4000 RPM.
• Do not let the engine labor. Never lug the
engine in high gear at low speeds. With a manual
transmission, shift to the next lower gear. This rule
applies at all times, not just during the break-in
period.
For the first 1,500 miles/2414 km:
• Do not participate in track events, sport driving
schools, or similar activities during the first
1,500 miles/2414 km.
• Check engine oil with every refueling and add if
necessary. Oil and fuel consumption may be higher
than normal during the first 1,500 miles/2414 km. -
period.
I agree with some of this.... but other than that, it's a good way to glaze your piston walls and prevent the piston rings from sealing properly. My break in period is whatever the distance is between my garage and the dyno.
With speakers, though, i typically stop hearing a difference after 100 hours, depending on the speaker.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
