turntable
first.....i don't know if this is the right forum for turntable questions,but theres a lot of knowledge here,so please help if you will.
the wife picked up an old pioneer pl-600 at the local goodwill this weekend.
it runs, butttttttttttt after playing about a 1/4 of the lp the arm starts skipping across the record. i adjusted the anti skip dial to no avail
i tried several different lp's and it did the same thing on all of them.
also , i am running the t/t thru an onkyo 806,when i switch to the phono mode i get a buzzing noise thru the speakers. doesn't happen in any other mode ,just get the buzzing when i switch to phono.
if this is the wrong forum...my apologies....and please direct me to to the proper forum.....thanks for your help
Post edited by chemical on
Hi chemical,
It sounds like the tone arm lifter is not fully lowered after setting the needle down and the tone arm begins to drag on it part way across the record. Take a close look at it while operating. Also there might be a set screw on the lifter to adjust its height. I had to take my freebie TT into the repair shop for complete lubrication and servicing.
As for the buzzing, do you have the ground wire from the TT connected to the ground connection on the receiver?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Can't comment much regarding TT's but as far as the buzz/hum problem this is the ground he's referring to on a set of cables.
There should be a thumbscrew on the rear of your receiver to connect your ground to.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I'm willing to bet the cantilever and stylus is shot.
hearingimpared wrote: »I'm willing to bet the cantilever and stylus is shot.
thanks for the help everyone,its much appreciated -
kawizx9r...............
In case you're interested, you can link to photos if you use Photobucket.
http://photobucket.com/Samsung HL61A750 LED DLP
Onkyo TX-SR805 receiver
Oppo BDP-83 blu ray player
Polk Audio LSi9 front speakers
Polk Audio LSiC center speaker
Sony SS-MB100H rear speakers
SVS PC12-NSD powered subwoofer
Pioneer PL-514 turntable
Logitech Harmony 628 Universal Remote -
have you set up the tone arm to the right tracking force? also called VTF - vertical tracking force. if it's to light.. the arm and needle will skip across the record. also, have you replaced the needle and or cartridge and needle together? on used turntables.. the first thing you should do is replace old warn out needles.PolkFest 2012, who's going>?
I know, I have a photobucket account myself....that link/pic I posted was just the picture/link from signal cables rca/phono cable to show the ground. Weird how its just gone now.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
