New to Home Audio...Need Help
jay27
jay27 Posts: 105
I've recently gained an interest in putting together a home audio system. Up until now, I've been a car audio person.
My question is...do the home audio receivers allow you to set all of the crossovers for each set of speakers manually like a digital signal processor would do in car audio? I am not looking to do surround sound, but I may want to add several speakers for a stereo setup. I would basically want to set the crossover points for each tweeter, mid, and sub electronically (high pass, band pass, low pass). Thanks for any help you can give.
Post edited by jay27 on
  • Zeros
    Zeros Posts: 940
    edited August 2009
    Most receivers allow for a low cut-off but that is to the entire speaker, not just the driver or tweeter. Home audio speakers have built in crossovers that control the frequencies to the driver/tweeter.
  • gavn8r
    gavn8r Posts: 53
    edited August 2009
    jay27 wrote: »
    My advice is to not over complicate things. A simple 2 loudspeaker configuration is really the best way to enjoy the music.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited August 2009
    yep, what they said....also, check out some of the 2 channel threads, lots of knowledge their. good luck.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • broven
    broven Posts: 1
    edited August 2009
    I as well would not bother with a crossover system in the home. if you are adding a subwoofer, then typically you may be able to control the low pass from the sub's end, but 2 channel is the best
    F1nut Posts: 51,944
    edited August 2009
    Forget everything you learned in car audio, you're stepping up to the big time now. AVR's are for HT, integrated's or separates are what you want for 2 channel. Your idea of having multiple speakers for 2 channel is a bad one, get one pair of very good speakers instead.
    treitz3 Posts: 20,081
    edited August 2009
    Amen. 'Nuff said.
  • danz1906
    danz1906 Posts: 5,144
    edited August 2009
    Correct!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    edited August 2009
    ^^^biased opinion.....^^^^
    Good one, but still biased. ;)
