Matching R300 with CSi A4 or CS A6(RTi centers)?
poop_on_you
poop_on_you Posts: 2
edited August 2009 in Speakers
Already did a search and I know the RTi series are not timber matched with R series.
http://www.polkaudio.com/forums/showthread.php?t=56416&highlight=r300+match
http://www.polkaudio.com/forums/showthread.php?t=47338&highlight=r300+match
Problem is, I don't know a cheap reliable place that sells CSR/CS10/CS20 in Toronto, Canada. Bought the R300 on sale in a package from Futureshop and it's missing a center, but the only centers they sell separately are CSi A4 and CSi A6..
I've heard that the center is the most important speaker in the system and that's where most of the money should be spent on. Will the CSi A series center sound ok with the R300 fronts or should I save my money and take my chances with ebay? Ideally, I want to buy a matching center from a place where I can get a full refund for open box in 30 days without them asking me why.
Thanks for the help.
Post edited by poop_on_you on
  • Zeros
    Zeros Posts: 940
    edited August 2009
    The Polk CSR goes for about $50 including shipping on eBay usually. I know because I have one and was thinking of selling it there. The CSR is a match for the R series speakers as well as the CSM (which I think is newer). I would go the eBay route for the cheapest matching center. I rarely have any problems buying speakers of eBay, just look for someone with good feedback obviously.
    You could also try a CS2 (replacement for CS20) which should be available locally. In this thread a few people said that it matched well with their R50 fronts:
    http://www.polkaudio.com/forums/showthread.php?p=1138202&posted=1#post1138202
  • SivaNevets
    SivaNevets Posts: 303
    edited August 2009
    heres comes a guy from RFD :D
    welcome to the club
    i would be it from ebay/amazon. gibby audio video in toronto has them but the price isn't great.
    never know theres CSM looks like a centre version of M10 :D i think both CSR/CSM will work perfectly with R300.
    (for ppl dont know, futureshop in canada is selling R300+M10+PSW10 for $280 CDN, wut a great price)
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • poop_on_you
    edited August 2009
    Thanks for the replies.
    SivaNevets, your advice is much appreciated since you are both RFDer and a Polkster. :D I guess I will save my money and try my luck on ebay. Gibby's is a little too far from me.
    I know CS10 and CS20 are supposed to match TSi, and CS1 and CS2 are supposed to match Monitor. I figure I might as well get the best "perfect matching" center if I'm buying from ebay.
    From http://www.polkaudio.com/search/older-models.php
    It seems the matching centers are:
    CS175
    CS175i
    CS245i
    CS250s
    CS400i
    CSR (perfect match for R series)
    CSi20 (perfect match for R series)
    CSi25 (perfect match for R series)
    CSi3
    CSi5
    Is this right?
    Also, the higher numbers mean they are better right?
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    I'd like to chime in regarding the CS245 and 400 simply because I don't know off hand (although I can look it up online) what the others are timbre matched to exactly but the ones I mentioned are part of the RT series. They all have dynamic balanced drivers (i and p series being identical except the blue-colored woofers) but their distinct characteristic, as opposed to the others above, is the tri-laminate tweeter used throughout the series along with ls-90's and the sort.
    If you can find a csr, get it since its the best match you can get. Honestly though if you have a store nearby with a polk center at a good buck (with a nice return policy) Id say give it a try for awhile and see how it suites you. If your ears can tell the difference or youre simply not happy with it, take it back! :D
    The higher numbers that fall within the same series of a speaker usually mean it utilizes slightly larger drivers i.e. the cs245 uses 5 1/4" mid bass drivers while the cs400 uses 6 1/2" mid bass drivers.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
