Need SQ highs and mids for 2 SR124-DVCs
pushkanak
pushkanak Posts: 45
edited August 2009 in Speakers
Hello,
I got two SR124-DVC, the Mb Quart DSC 1500.D amp to power them, and the Pioneer PRS800 head unit to augment SQ. And now, I'm trying to find the mid and high speakers to try to achieve the best possible SQ system together with those subs.
I've narrowed my search to the following 2 amp setups, depending on the highs and mids chosen:
1 amp JBL GTO1004 or
2 amps Focal Solid 4
Regarding the mids and highs speakers, I narrowed my search to the following final choices (all these are adjusted to my maximum available budget):
1 set polk SR6500 front stage
1 set Focal 165A1 for the trunk
1 pair Alpine SPS-600 for the trunk
1 set polk MMC6500 front stage
2 sets Focal 165A1 for the trunk
2 pairs Alpine SPS-600 for the trunk
1 set polk MMC6500 for the trunk
1 pair mids powerbass 4XL-65-92 in the trunk
1 pair super tweeters powerbass S-1s in the trunk
1 pair mids Eminence Beta-6a in the trunk
1 pair super tweeters Super Tweeter Jbl P26t in the trunk
1 set of focal 165 A1 front stage
1 set of focal 165 A1 rear doors
2 sets of focal 165 A1 for the trunk
Well, those are my possible choices available in the local market, and one of both amp setups should be chosen depending on the choice for mids and highs speakers.
Please remember that, while it seems that I can't pursue a pure SQ system having two subs at 1400 rms total, my main goal is to achieve the best possible sounding system with the two polk SR124-DVC subs and the PRS800 pioneer head unit(want more SQ than SPL), without any frequency range overpowering the other. Also, remember this is for a 2007 Jeep Liberty.
I will really appreciate your recommendations. Thanks.
Post edited by pushkanak on
