Center Channel for polk rta 8tl's
KairosZenith
Looking for a center channel that would go with the old polk rta 8tl. Or would i have to take the drivers and crossovers and make my own, and if so, what would the dimensions have to be for the box/cabinet?
Post edited by KairosZenith on
The CSi5 or CSi A6 would probably be your best bet as far as the newer center channels go.
The ideal solution would be to build a matching center using the same drivers as the RTA 8TL though.
If you decide to go that route, you might want to post a thread in the DIY section of the forum.
By the way, welcome to Club Polk!:)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Get another RTA 8TL and lay it on its side.
Seriously, tho, I don't know if Polk made a center with the SL2500 or RDO198 tweeter.
Good luck."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
I have a CSi5 I am using with my RTA-8TL's and I think they blend very well.
It's 6.5" MW's carry much better bass than the 5.25" MW in the CS1 I had before. As far as I know the 8TL's are the only speakers with the MW6516, so i you wanted matching MW's you would have to build one.
I do find that I typically 'tune it down' 3-4db with HDtv HT (comcast) but that maybe just me. (I don't think they are broadcasting alot of channels in true 5.1) I don't usually need to for movies or music.
FYI: there is one in the FS right now for a great deal. Half what I paid a couple of months ago.
