should I ?
I have the oportunity to get some lsi9's for $399 from a local seller. although cosmetically not perfect, ( scratches and blemishes ) they do sound perfect.
just wondering what everyone thinks. i know i need to weed out some inventory to accomidate these so thats whats holding me back
Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
Post edited by sandworms on
What would you use them for? A 2 channel rig?
I'd probably would want a better deal for "worn" 9s.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
i was thinking about going with the lsi's for my frts in my living room, and either selling the rti10's or moving them elsewhere. then eventually getting an lsic for a matched front stage. so you think it's too steep? i was a little hesitant, so if he doesn't go down $ i'll just passSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
The LSi's would match pretty well with the electronics you have now. If you are ok with the cosmetic blemishes, I would go for it. If they have a warrantee I would take it (like floor models at a store) but if they are from a private seller, I would try to get the price a little lower.
It might be worth asking how old they are, how they have been used, how the cosmetic blemishes were acquired.
I got a pair this year for a few dollars more 10 months old with the boxes in perfect condition. The only downside was I had to finish breaking them in. I know breaking them in is hard work. N8 When the music's over...turn out the light. -
thanx for the input guys, i decided to pass on em. if anyone else wants them they may still be in rochester craigslistSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
