RT3000p Wiring Help
coasttal
coasttal Posts: 12
These are the speakers that have the subwoofer below and the higher frequency speaker above.
Normal wiring is to run your + and - cable from the binder posts for your left and right sides and then first go to the subwoofer and then jumper to the speaker above.
I just moved and need to separate these two speakers by 30'. I want to double the wires coming from the + and - binder posts on my receiver and send one set to the subwoofer and then one set to the higher frequency speaker.
Is this OK to do?
Post edited by coasttal on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited August 2009
    I wouldn't. That would change the impedance that your amp is seeing, and would cause it to work a lot harder.
    What you could do is make a custom pair of jumpers that would go the required distance between the two cabinets. Just run the cables from your amp to one of the cabinets, and then have a 30' pair of jumpers going to the second cabinet. That would probably be your best option.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • coasttal
    coasttal Posts: 12
    edited August 2009
    Yep, that is exactly what I figured.
    I should have read my manuals before pulling wire underneath a very cramped, nasty, wet crawspace. Had I read the manual I would have just run a dedicated subwoofer cable and then done a y-split.
    Kicking myself this morning.
