Wife says hears constant buzzing
CaligulaPolk
CaligulaPolk Posts: 1,650
edited August 2009 in Speakers
on my Center: Polk Audio CS245i speaker. It was working before i hooked up to amp.
Now it is not working and wife can hear constant buzzing when she put her ear up to the center speaker. it was very low buzzing sound and just now she tried that again, no sound at all.
my two fronts works fine..
does this mean my center broke or blown?
Anyone wanna talk my wife on the phone and help??? PLEASE!!! Perhaps listen on the phone?? PLEASE HELP! Thank u
I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
Post edited by CaligulaPolk on
  • speakergeek
    speakergeek Posts: 555
    edited August 2009
    Are you certain you have all of your RCA cables connected to the correct inputs on the reciever? And your speaker wires to the proper speakers?
  • CaligulaPolk
    edited August 2009
    Im sure..... hmm... i double checked and i think so... She said it sounded like its trying to power up
  • speakergeek
    edited August 2009
    You could try hooking it to another channel on the amp just to rule out that channel as being bad....What does the amp do when you first turn it on?
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2009
    Swap the center speaker with the front L or R temporarily to determine if the problem is with the speaker, or with settings/connections/amp.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • megasat16
    megasat16 Posts: 3,521
    edited August 2009
    Ok! The constant buzzing she hears from the center is low level hum usually caused by ground loop problems. You can try lifting the ground by using a cheater plug and see it disappears. I guess it's best you let your wife reading this thread since there will be a lot of suggestions for her by many other folks here.
    If there is nothing coming out from the center and you think you hooked up the wire correctly, first check your AVR to make sure it's not in stereo mode (it should be in some kind of surround mode). Also, check your speaker levels for center channel. If all is well and still no sound from the center, you need to switch the rca cable to see if it helps. Sometimes, the faulty (shorted) RCA cables will cause the problem. After swapping the cables and still no sound from the center, hook up the center (and center rca) to a different channel on the amplifier and see it works now. If it does, your amplifier center channel is out. If it doesn't, ask other folks here.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • CaligulaPolk
    edited August 2009
    tcrossma wrote: »
    I switched FL to center and center is working and FL is not...
  • speakergeek
    edited August 2009
    Double check the center connections and make sure all is well in the AVR configuration...
  • tcrossma
    edited August 2009
    You now know that it's not the speaker. It could still be the amp. To check that, swap the IC cables on your amp -- swap FL with Center.
    If it's not a bad amp channel, then as megasat suggested, check IC's, speaker cable connections, and AVR/processor settings to make sure the center is turned ON and that a mode that outputs to the center is selected.
  • CaligulaPolk
    edited August 2009
    megasat16 wrote: »
    ah all three works now.. wife accident press stereo mode on avr..
    i changed it to neural THX 7.1 channel on avr.. it works..
  • speakergeek
    edited August 2009
  • CaligulaPolk
    edited August 2009
    Wheeeeeww!!!!!
    WHOA!!! SPEAKERS ARE SINGING!!!! HARD!!!! i think amp made bass difference
  • speakergeek
    edited August 2009
    tcrossma wrote: »
    I guess my suggestions don't count eh???:)
  • megasat16
    edited August 2009
    Glad it's working now. :D Sometimes, we all did that mistake. :o
  • CaligulaPolk
    edited August 2009
    wheeew!! :D
    thanks for the help guys... Top Notch helper in here :D
    but shame on peiople who viewed and said nothing lol
  • jimmydep
    jimmydep Posts: 1,305
    edited August 2009
    I just got here but.....check to make sure the AVR is in surround mode and not in stereo mode, That should fix your problem
    Jimmy
  • McLoki
    McLoki Posts: 5,231
    edited August 2009
    Next time ask "Are you sure? I don't hear a thing....."
    Thats all I got..... :D
    Michael
  • messiah
    messiah Posts: 1,790
    edited August 2009
    Me too. Glad you got it fixed tho!
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • CaligulaPolk
    edited August 2009
    McLoki wrote: »
    Michael
    LOL thats hilarious.. u know the answer :D
    Thanks las and messiah.. im just glad it was avr setting not blown speaker
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited August 2009
    jimmydep wrote: »
    Jimmy
    +1
    I can sense that this will most definitely probably fix your problem if you're
    lucky.
  • gavn8r
    gavn8r Posts: 53
    edited August 2009
    My wife hears a constant buzzing, too. But I don't think it has anything to do with hi fi.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2009
    Cable is notorious for ground loop hum. Cure it with a TOSLINK connection from the cable box to your processor.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
