I am now convinced on the SRs
Thunderplains
This morning I had a chance to hear the 165KR2s up against the SR6500 and not being a SQ nut, I simply closed my eyes and listened.
Between the 2, the focals seemed to have a little advantage in the midbass, almost not noticeable. But the SRs highs blew the focals away..
And being the first time I heard the focals and second on the SRs, Polk has a winner with these comps..
I guess the ring tweeter is the key, but it was very impressive.. I KNOW I made the right decision as far as comps go.. without question..
I dont know if the KRX2 or the KRX3's will make a huge difference,
but I am happy..
but I am happy..
Post edited by Thunderplains on
Make sure you get those tweeters as on axis as possible. Theyre non existent off axis and wont resemble what you hear in the showroom. Their only really weakness honestly.polkaudio sound quality competitor since 2005
Thunderplains wrote: »This morning I had a chance to hear the 165KR2s up against the SR6500 and not being a SQ nut, I simply closed my eyes and listened.
but I am happy..
.......and you're saying that you're not a sq nut
welcome to the nuthouse buddy.
I have heard the focals and recently I got a chance to try the sr's. Your observations are accurate. -
haha ... ok.. my SRs get good midbass.. nvr heard the competition.. but u can seal u'r door properly and get fantastic midbass.
(disclaimer... a dedicated 6" for 50hz to 100hz will yeaild better results. but then u'r talking 4-way active.. and that's some work doing) -
This is going to be a sickness..:eek: -
Thunderplains wrote: »This is going to be a sickness..:eek:
you bet. Like Mac said in the other thread SQ is about tuning, install and equipment. You've got the equipment end done. Now gather as musch info as you can on the install bit. Ask here and you will get lots of help, tips and tricks on install. -
Dude, you have no idea.
I cant count the amount of money and time Ive spent on gear, tuning, going to shows and such. Ive often sat in my car for 4-6 hours straight just tuning. And Ive loved every minute of it!polkaudio sound quality competitor since 2005
Yep, sickness.
i love mine too
no one belives me that its just one component system..
also my sub is very low in frecuencies, so must songs dont activate the sub and the SR comps handle very well the mid bassZ
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
KnuKonceptz MKS Kable -
I have been loving my SR's since the first month they came out and I had to grab a pair. I was just about to go with the Focals or JL Z's, but the Polks destroyed both of them in overall smoothness.
...i wish i could afford SR's....i'm working o my new system now, my pride and joy. hopefully it will blow away any of the competition i might have in my area. so i wanted to invest in some good quality components for the front. i looked at my options and considered some of the higher-end boston acoustics systems and finally settled on the infinity kappa 680.9cs. I just didn't want to go with the db6501's because these front speakers are replacing db651's and I didn't want to go entry-level again, as highly regarded as the db6501's are. I'll be mounting the tweeters in the top of the door panel close to the a-pillars. i've decided this system has to eat other systems for lunch because I have a reputation to maintain...so unfortunately there are a million expensive directions I could take this to improve my system. SR's might be one of those upgrades if the infinity's don't cut it, but the head unit will be the first to goIn-Car:
Head Unit: Sony MEX-1GP
Door speakers: Infinity Kappa 680.9cs
Rear speakers: Polk db690
Subwoofers: Memphis Audio 15-M3124
Amps: Pioneer GM5300T, Kenwood KAC 6020, Memphis Audio MCD1.1100
In-Home:
Harmon/Kardon AVR 230
Harmon/Kardon DVD 101
Yamaha RX-V995
Bose 161
Bose 901
Polk FXi30
