Comparison Opinions Please
Fud
Fud Posts: 16
edited August 2009 in Speakers
RTi A5 vs Monitor 70(at half the cost);) vs Energy c-500(retail).i will be using an onkyo 607 avr.thanks
Post edited by Fud on
  • danz1906
    danz1906 Posts: 5,144
    edited August 2009
    Go for the A5, Its a really good speaker.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    nooshinjohn Posts: 25,484
    edited August 2009
    +1 for the a5... were it not for my affinity to the SDA's I would have a pair in my home. They are elegant to look at and sound fantastic when hit with good clean power...
  • Fud
    Fud Posts: 16
    edited August 2009
    yes,these speakers will be used primarily for stereo music listening.would the onk 607 be enough for the monitor 70?if not,what would the effect be?hardware burnout or limp sound output?thanks for the reply's so far
  • hydrostream
    hydrostream Posts: 549
    edited August 2009
    No sure about the a5s or the 70s but i had RTi10s and picked
    up a pair of C-500s. The 500s kick **** for 2 channel no idea
    how they would be in HT. I have them powered by an adcom
    200 wpc amp and they Rock. The best part is i only paid $150.00
    each a few months back from World Wide Stereo and they shipped
    free. To bad they don't have that deal anymore or i would have a
    set in the garage too.
    jerry
    Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
    Basement-Audiosource pre/tuner,GFA-545,Onkyo
    DX-1400 and RTI10s
    Garage-GTP-450,onkyo M-282 and R50s with RTi55
    drivers and X-overs.
    My baby 18' V-king Mod VP with a merc 2.4 BP.
    KTM 620 Supermoto
  • RandyBox
    RandyBox Posts: 125
    edited August 2009
    Since you threw the "1/2 price" in the mix, I'd say 70's all the way. I still believe the bargain factor has to be considered.
    Randy
  • Fud
    Fud Posts: 16
    edited August 2009
    what about Rti8's are they comparable to Rti5's.how well are they constructed?and ill throw in energy cf-50's for good measure.my tsi200's are not cutting it for me,sorry.thanks
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited August 2009
    Fud wrote: »
    RTi8's and RTiA5's are essentially the same speakers. The use the exact same drivers and XO's, with a slightly different cabinet geometry. The curved cabinet design of the A5's makes them a little bit more acoustically inert, and helps tame down the brightness a little bit. It also warms up the midrange slightly.
    IMO, the Monitor 70's would be a better choice for music, and the RTiA5's would be better for HT.
    I have a pair of RTi8's, and I can't stand them for stereo music listening. The tweeters are just way too bright sounding. If brightness is what you crave, they may work, but for me they didn't. I almost never listen to music through them. They're great for HT though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Fud
    Fud Posts: 16
    edited August 2009
    well,ive gone with energy cf-50's.sorry polk you loose this one.the tsi/monitor line did not cut it for me.i never was very interested in the rti line.after comparing rti to monitor what else can i say.the lsi line is a bit out of my price range.although the lsi's are on my dream list for now i settle.i will say polk makes very well constructed speakers and i respect that.salute
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited August 2009
    While in the end it was your decision, I think you may have been a bit quick to dismiss the Monitor series. I have Monitor 70's and while they are currently being pushed by my Onkyo TX-SR806 quite well, I can't wait to hear what the sound like with an external amp powering them. The Energy line is made by Klipsch right? At $400 a piece you could have picked up two Monitor 70's at that price. Like I said though it was your decision to make and as long as you are happy, that is all that matters. Good luck and welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • vijayl
    vijayl Posts: 258
    edited August 2009
    xcapri79 wrote: »
    With a good receiver or external amp, the Monitor 70's sound better for music in my opinion. I like the RTi A5 for HT.
    +1 on M70, as ur more interested in Music.
    I wud consider Pio SC-05 or SC-07 or Onk 805/806
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
