PS3 Slim outputs DTS-MA, Dolby TrueHD via bitstream
lanion
lanion Posts: 843
edited August 2009 in Electronics
decode new formats in your processor rather than an on old ps3 which did all decoding on board for the HD audio formats.
http://gizmodo.com/5342470/so-the-ps3-slim-can-bitstream-dolby-truehd-and-dts+hd-master-audio-after-all
Nice update.
My Iron Man training/charity blog.
HT:
32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
Post edited by lanion on
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited August 2009
    NOOOOOOOO!!! Now I have a quazi valid reason to get a new slim ps3... I wish they kept the piano black finish though :(
  • pablo_rodz
    pablo_rodz Posts: 331
    edited August 2009
    NOOOOOOOO!!! I wish they kept the piano black finish though :(
    They didn't, now is a cheap looking matte finish. Also instead of the touch sensitive buttons they put actual (cheap looking) buttons.
    But you can buy my mint <1yr. PS3 80Gig, with the Bluetooth remote and an HDMI cable.:D
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2009
    That's the only negative with the current models. No bitstreaming
  • cheddar
    cheddar Posts: 2,390
    edited August 2009
    Internal ps3 decoding to PCM as an alternative lossless option works great. But for those who have to have the little lights on their receiver active, the slim's upgrade is good news...
  • leroyjr1
    edited August 2009
    cheddar wrote: »
    With my Pioneer Sc-07 I noticed better SQ when having my receiver doing the decoding vs the BDP doing the decoding.
  • cheddar
    edited August 2009
    With certain AVRs, there are additional adjustments you have to make to the PCM to get the subwoofer level to play properly. The LFE channel is recorded at -10db. In the AVR, it is supposed to be automatically boosted +10db before being sent on to the amplifier. Some AVRs don't apply this boost to the PCM input and users often don't know they have to add the boost manually in their set-up options. So the playback sounds thin without the extra bass.
    Properly set-up systems should sound fine with PCM input. But having the decoding done in the AVR eliminates having to worry if your system is applying the boost properly or not.
  • leroyjr1
    edited August 2009
    Referring to clarity.
  • cheddar
    edited August 2009
    Well, if your LFE input is not calibrated properly, then perception of clarity will suffer. It's easy enough to test. Just bitstream the vanilla Dolby Digital option off a blu-ray. And if even that has more bass than player decoded TrueHD, then there is a problem with the LFE channel.
  • JohnLocke88
    edited August 2009
    pablo_rodz wrote: »
    I already have a 40GB i got back in October of 2007; Thing has worked perfectly for the almost two years i've had it. My only gripe has been that I can't see the little lights glow on the receiver... completely neurotic, but... there you go.
