Monitor Series: When the Magnet Fails...
Klop
Klop Posts: 5
edited August 2009 in Vintage Speakers
Hey guys,
after receiving some helpful info in my first post, I now have a chance to contribute a bit of my own.
Recently I bought a "new" set of MW 6502's & decided I'd take some time to use Polksaladanni's JB Weld insurance policy on my 4 drivers before they failed.
However, I began doubting that the location shown in his pictures was the correct area to glue when compared to the repair shown here.
So as I began prying on my seized driver, It popped apart & guess what?
That's not the right spot!
So please update, your bookmarks, stop the presses & make note of how these things separate. ;)
The "inner plate" is not likely to ever shift as it has 4 solid mechanical attachments to the basket. What does fail, however, is the magnet & back plate (pole piece) just behind it. My picture is a little blurry, but you can see the original ring of glue on the magnet.
So if you'd like to help protect your drivers against the slip of death, apply a generous bead of JB Weld to the following areas:
1. Where the magnet ring meets the inner plate
2. Where the magnet ring meets the outer plate (pole piece)
And Polksaladanni, thanks for the JB Weld idea & I hope you'll forgive me for the correction. :)
  • skrol
    skrol Posts: 3,438
    edited August 2009
    Thanks. This is great info.
    Stan
    Main 2ch:
    HT:
    Other stuff:
