Trying to help a buddy out.
kaisersose
A friend of mine is doing a renovation to his house.
He has already had his room wired for 7.0 with wall outlets.
Currently has a pair of ceiling mounted RC60i mounted.
He was going to use his Bose acoustamass for system for his front channels. I advised him against that.
So I have been helping shop for him around the usually places.
I found a nice set, locally, paradigm towers monitor 7 and a center, of course the dreaded comment from the wife. I do not like the finish came out.
So I just got back from a house looking at the this set up.
Does anybody know what model the towers are?
I looked on google under images and thought they might be Polk RT12 .
I also found him a set of Klipsch towers newer WF icon line as well as an older set of Polk RT1000i powered towers.
Any help is appreciated.
Post edited by kaisersose on
Yes they are Polk RT12
Mid/Woofer 2 - 6-1/2" Diameter (16.51cm)
Dynamic Balance® drivers
Tweeter 1 - 1" Diameter (2.54cm)
Dynamic Balance® tweeter
Electrical
Overall Frequency Response 28Hz - 25kHz
Lower -3dB Limit 42Hz
Upper -3dB Limit 23kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20 - 250 w/channel
Efficiency 90 dB
Dimensions
Cabinet Size 36-3/4" H x 7-1/2" W x 12-1/2" D
(93.34cm H x 19.05cm W x 31.75cm D)
Footprint Size 8-3/8" W x 12-1/2" D
(21.27cm W x 31.75cm D)
Enclosure Type Vented via floor-coupled Power PortLife without music would♭ -
Thanks for the help.
He is going to pass. They are not nice enough looking for their room decor. -
Tell him to look into LSi line. NOt sure his budget, but they are swell looking
PaulyLife without music would♭
