help one of my SRs is dead
Kinetic
Kinetic Posts: 437
edited August 2009 in Car Audio & Electronics
guys i think that my drivers side woofer is not working anymore, i already check the RCAs, and the speaker wire (on the amp, crossover, and speaker)...
and i think its the driver...
it could be the wire ( some part inside the carpet) or the crossover, but i dont think so becouse the tweet is working fine, but i will check them on the weekend..
but if its the woofer what can I do??
it doesnt smell like burned, and it looks fine at first glance..
i have the SR6500
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Post edited by Kinetic on
  • unrealii
    unrealii Posts: 268
    edited August 2009
    If it is the woofer, you can call up polk and order a replacement woofer. Tell them you are part of club polk forums and you'll get 20% off and free shipping (this was last time I ordered). Replacement isn't going to cost too much, but it comes bare, so save all the parts off of your old woofer.
    I think you need to get a multimeter to check wire continuity to the speakers.
    LSIm system on order =D
    Currently listening to innovation...
    Prior car systems:
    Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
    Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500
  • jay27
    jay27 Posts: 105
    edited August 2009
    Polk customer service is pretty awesome. They are prompt and the ability to order each piece separately is great.
  • Kinetic
    Kinetic Posts: 437
    edited August 2009
    I will call polk tomorrow, and I will try to check the driver today..
    and thanks a lot for the advice, I really appreciate it guys
    Z
    Polk Audio SR 6500
    G35
  • arun1963
    arun1963 Posts: 1,797
    edited August 2009
    hi kinetic,
    like u said, over the weekend first confirm if the mid is really blown and if so why?
    btw tks for the sheet.
  • Kinetic
    Kinetic Posts: 437
    edited August 2009
    guys it wasnt the driver..
    it was a problem with the crossover, but it was solved easily...
    the thing is that i hit a pot hole in the road, and since I have a lowered vehicle and a rock solid suspension, the hit was actually very hard, and one of the cables on the crossover get loose or break...
    I went to my local shop to check it all with a multimeter, and find the broken cable, next to the crossover..
    So guys thanks a lot for all the help, I really appreciate it..
    And I was so scared =( but thankfully it was only the cable..
    Now I love more my SRs
    Z
    Polk Audio SR 6500
    G35
