Ported Sub Blue Print
Shicks18
Shicks18 Posts: 397
edited August 2009 in DIY, Mods & Tweaks
Let me know what ya'll think!
TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3
Post edited by Shicks18 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    3' tall?.........my wife would kill me lol. Looks good though although did you make the box that size for lowered frequency response paired with the flared port? I want to keep my DIY sub enclosure the same size if not smaller than what the model it comes from uses so I'd have curved ports inside the box. Also thought about an active woofer/passive radiator design....hmmm
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    Yea, some guru at home theater shack was giving me input and said I needed to it around 9 cubic feet in order for a good tuning of 18hz. it had something to do with air travel yada yada
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • kawizx9r
    edited August 2009
    Yea, I just purchased an HSU v-1 driver from jephood on this forum and well, the box dimensions for the model it comes from isn't that "small" either. There are alternatives though you can look up online, I mean sure youd need some space for the air to travel through for some good tuning but it doesn't have to be a straight pipe either. I saw pics of "external" ports that wrap a long ways around the exterior of the subwoofer.
    EDIT: Added pic
    Ugly I know, but just thought I'd show ya how far people go sometimes.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    I am going to put some matching veneer around the cabinet when I am done to make it look at pretty and blend in.
    I think that sub you posted will be way more of an attention getter than my sub! hah
    Also, I plan on puttin the sub behind a chair in the corner, only thing that will be visible will be about the top 10" or so.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    Thats a good driver, but your gonna have a hell of a time finding the T/S Parameters to tune that baby correctly.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • kawizx9r
    edited August 2009
    Im not really too sure about how it will come out, but I'll surely post pics of the project once its all done. What driver and amp are you using? If you can pick up a stereo amp that you can bridge, or anything thats stand alone it should be better (in terms of heat/efficiency and sheer output) as opposed to a plateamp. I might go plateamp anyway due to lack of space for another amp, running another set of speaker wires and cost.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    Dayton 15" HF and Bash 300. I wanted a plate amp so I don't have to buy an equalizer or also buy a high pass filter. The Bash 300 comes with an HPF at 17.7hz, helps limit over excursion.
    The Dayton driver is also a max of 500 Watts, no use in buying an external amp to get more watts than it can handle. Don't want to blow the sucker.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • kawizx9r
    edited August 2009
    I talked to Parts-express yesterday and well, they couldve either lied to me or told me the truth but they were saying that their dayton amps ran cooler than their BASH plate amps, and recommended them for stability if I were to "drive it hard."
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    I think you would be okay with either. If you go with dayton and get a 240watt plate amp, just get the normal one. Not the one with the boost at 30hz.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • kawizx9r
    edited August 2009
    Oh trust me I wouldn't have gotten the boost for anything. My thing about "boosts/enhancements" is that anything you "boost" will be artificial and shouldn't be done because at higher volumes it can lead to some nasty distortion. If using any type of equalizer, I'd prefer to "subtract" from some part of the frequency range to tame it.
    As far as amp goes, I'm looking at a 500watter....and a nice sized box since space won't be much of an issue. I had a Velodyne CHT-12 (400watt/12" slot loaded son of a gun) with a Polk PSW-10 on top of it. Now that was a huge stack.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited August 2009
    Any progress on this thing? My driver came in today, can't wait to start working on things :DSNV11799.jpg
    Excuse the dust :rolleyes: thats what happens for taking pics @ 10MP
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    Wow, nice sub!!!!
    Actually, I think I might be able to get around to it next week sometime. I actually bought all the MDF and Oak Plywood a few days ago.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
