carver tfm-35
cliff8282
greetings, i am new to this forum and am considering purchasing this amp. the owner states and i quote
"Please note that late last year I began to have to rotate the amp's input level control occasionally on start up (big knob on the far right in the photos) because the right channel seemed to be playing softer. After that, it worked perfectly. The input level control may need to be sprayed with contact cleaner. I don't know if this signals a bigger problem with the amp, but I needed a surround amp, so this one needs to go. I will guarantee the amp to not be DOA. "
could anyone tell me how serious a problem this could be and should i consider this amp?
thx in advance
thx in advance
Post edited by cliff8282 on
Depending on the asking price, you may consider purchasing and sending it off to Bob Carver. He'll make it good as new.Technics SL1210mkll / AT125LC / Cambridge Audio 640P / Yamaha TX-950 / Onkyo TA-2600 / Yamaha C-80 pre/Adcom GFA 545 / Polk Audio Monitor 12 Series 2
So does Rolland at Carveraudio.comSpeakers: SDA-1C (most all the goodies)
thx in advance
cliff8282, you could PM beemers417 about this, as he is an expert on fixing such things. I do believe that it is simply a contact point is a little dirty and just need cleaned. beemers417 can tell you exactly where to spray, beacause I ran into the same problem with mine and he fixed it.
Also before you buy, you may just consider buying one from beemers417 at : www.vintagehifipgh.com
I hope this helps you out cliff8282.----Take Care, B.B.3Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's
