is this a good surge protector?
SivaNevets
scared of thunder to break my treasure...
and dont want spend a lot money for it
is this any good?
http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=021860&cid=PWP.985
Belkin PureAV Isolator Home Theater and PC Surge Protector 4720J Dual Coax Power Filter 10 Outlets (F9A1033-10-SC)
Power Filter Technology (PFT)-Isolates contamination to prevent AC and EMI/RFI to help provide quality sound and picture
Satellite, Cable TV, Antenna Coaxial Protection-Protects connected components with one pair of gold coaxial connectors designed to improve signal; also protects cable modems.
are they useful features that will make a difference?
is this any good?
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Post edited by SivaNevets on
Here's a thread I started a little while back, if you read the comments others left below you'll gain some need-to-know stuff and what to look for. Definitely helped me out, running now a Panamax 5100Max power conditioner. Why go halfway with a surge protector as opposed to spending a little more for better peace of mind and clean power? You're more likely to lose gear due to brown-outs/etc as opposed to lightning killing your equipment. And even then, you'll still lose something if that were to happen. If the storms are REALLY bad I just unplug some equipment.
http://www.polkaudio.com/forums/showthread.php?t=85831Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Nice thread, kawie!
Regarding that surge protection, it will probably work as a surge protector, but we will have to look at the internals to see what kind of power filtering it can do.
I am currently using Belkin PF60 (I have seen refurbs at Factory Direct for 199 a while ago), and that one uses some decent power filters and surge protection.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
