Which TT should I consider?
fbm211
Im looking at two TTs and wonder which is better--the sony ps-lx2 or a numark tt-1625...The sony comes with a so called decent sure cart and the numark with a stanton cart. Prices are 20.00 for the sony and 60 for the numark.I assume the numark is better and I could get two of them for 100.00.But Im also wondering if my old HK T-55c is better than either...Any thoughts?
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Just my opinion but I think your HK beats both the Sony and the Numark. The Sony is better than the Numark for sure. The Numark is more recent but personally I'd save you money on either of them. My .02SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
the hk is far better than either; quite a good tt and arm, actually.
