novice buying speakers
hi i just bought a DEH-P7450MP deck for my new lancer. i dont know much about car audio but i paid $600 for the deck and am told its worth $1100...can someone tell me if this is a good deal?
im about to buy some speakers and was under the impression that they cost about $200 for good ones. ive been told its a waste of a good deck if i buy average speakers so i should spend $400-$500...true? can anyone recommend GOOD speakers to buy in the sydney area? Hopefully around the $300 mark. THANKS
Post edited by foxylady on
foxylady,
Near the bottom of this page is the "On The Move" section for car audio. I think you'll find more help there.Political Correctness'.........defined
President of Club Polk -
just to help you out good speakers need a good amp not the cheasey amps in the deck. i would recomend getting a poweramp forst then get beter speakers.
Go for polk mobile speakers first but if not the only other car speakers i would suggest is MB QUART-Polks first thoSystem #2
Yamaha cdc-755,(20 bit DAC )
Yamaha KX W382 cassette deck,
ADCOM GFA-545-II.ampfilier,,
ADCOM GFP-450 Preamp ,,BBE audio Restoration System (ARS)--Monster--M850I Innerconects and Monster 14 gauge speaker cable and the Fabulous POLK RT-7's with a Velodyne 12/15 subwoofer system ....she rocks.........
System #1:
Meridian 508-24 cd.(20 bit DAC)
Adcom -Gfp 750 preamp,
Bryston 14b-sst amplifier,
Martin Logan Prodigy Electrostatc speakers.and Acoustic Zen Silver Reference II innerconnects (rca) with Acoustic Zen Satori Shotgun speaker cable.
............................. "Jazz is democracy in music".
