trying to find a mate to my Polk Audio Monitor Series 2 speaker (single)
rifftrax
rifftrax Posts: 5
edited August 2009 in Vintage Speakers
Someone recommended that I hit up the polk audio forums to check...
I'm not sure the best way to go about trying to find a mate to my single Polk Monitor Series 2 bookshelf speaker that I found at a thrift store. It's in great condition and I'm anxious to see if I can't find another single one to complete a pair.
It has a 5&1/4" woofer it looks like and a 1" dome tweeter with the words "Polk audio" surrounding the tweeter. It's rather heavy and front ported with a grill that has the "i" in audio as a heart (???). Interesting. Anyway - does anyone know the best way to find the mate to this orphan? :confused:
any help will be very very appreciated.
Post edited by rifftrax on
  • Bobsama
    Bobsama Posts: 526
    edited August 2009
    Pictures would be immensely helpful. The speaker is likely close to nearly 2 decades old now, so it may or may not have a serial number. It's usually in the top-right corner of the back panel.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • rifftrax
    rifftrax Posts: 5
    edited August 2009
    okay...pics - here they is:
  • agfrost
    agfrost Posts: 2,430
    edited August 2009
    Looks like the Monitor 4.6, Series 2 (see HERE).
    Check below the UPC code on the speaker's sticker--I believe it may have the model number in small print there.
    Jay
    Jay
  • Bobsama
    Bobsama Posts: 526
    edited August 2009
    Monitor 4.6 Series 2, I think. At the moment, eBay has a ton of older Monitor 4's, but I haven't seen anything Series 2 on there in a while. You may be interested in a pair of bigger Monitor series. M4's were alright, but always rather entry-level. Look across your local Craigslist as well as eBay for Polk; Monitor 5's are nice but lack bass extension. Monitor 7's are relatively balanced, but the cabinets are on the large side. Monitor 10's are quite big, but tend to be considered a bit bassy. All depends on your definitions, however. Craigslist would be an ideal place to start; Monitor 7's and Monitor 10's literally pop up all the time.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited August 2009
    rifftrax wrote: »
    I'd consider parting it out and using those funds to go towards buying a complete set. Finding singles will be very hard.
  • rifftrax
    rifftrax Posts: 5
    edited August 2009
    Right...I could try it. I just really like hearing new sets of speakers (I've bought over 27 pairs of speakers in the past 4 months!) and getting my fill...
    But it's true that it will probably be difficult to find a mate. I will be checking the thrifts just in case though.
  • woodsman10b
    woodsman10b Posts: 408
    edited August 2009
    Find another pair to match and use the one you have for a center, just a thought.
    Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
  • concealer404
    concealer404 Posts: 7,440
    edited August 2009
    rifftrax wrote: »
    Pics of the 27 pairs of speakers? :D
