Up In Smoke.....
Systems
Hello
Had a little scare, well big scare, at the house the other night. I was laying in bed watching tv and I kept smelling something, electrical smell. I have a Panasonic plasma and a directv hd dvr plugged into a monster power surge protector.
I live in the family farm house, was built in 59 and the outlets upstairs are the original three bank two prong type. I had an orange three prong adaptor plugged into the surge protector and into one of those outlets.
Anyway, I looked around in back and couldn't really see anything and decided to check it out more and was putting on my robe when the receiver started freaking out and I could hear this zzzt, zzzt, zzzt. Looked at the outlet and was putting out a pretty good light show where the three prong adaptor was. I know this was a wrong move on my part but I reached down and jerked the plug out, but I was willing to sacrifice my life for my Plasma tv:) I didn't get shocked but did burn my finger a little on the melted plastic.
This is where things really got interesting. The adapter stayed plugged into the outlet and it was still melting and smoking and then all of a sudden things really shorted and it looked like somebody was welding back there, I **** you not. More smoke and flames and the breaker finally blew...
After the smoke cleared I got the adapter out, not much left of it, and took the outlet off to see if everything was okay with the wiring. The wiring was fine, looks like the issue was in the adapter. I've had this plugged in there for pretty close to a year now and am not really sure why this all of a sudden decided to melt down. The Tv and the receiver were also okay.
This all happened the night before we left on a trip, thank god we were here. Needles to say we went around and unplugged everything in the house before we left.....And, I will also be updating the outlet....
Testing
Testing
Testing
Testing
Testing
Wow glad everything turned out alright.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Looks like Lightman has been up to his old tricks... and glad all is wellThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
That's a serious bummer. I hope nothing happened to your plasma. While it may not have killed it, electrical issues like that have a way of shortening life expectancies of electrical components. Also, I'd think about replacing the surge protector now.My equipment sig felt inadequate and deleted itself.
Count your blessings, that was definitely one of them.Political Correctness'.........defined
President of Club Polk -
Have someone check your circuit breakers, if you had a light show with sparks flying, the breaker should have tripped. Glad you're alright and that your plasma survived.
Jimmy -
Jimmy
Yes, it should have tripped right away. Am going to replace the breaker too.Testing
Testing
Testing -
Some stories do have happy endings:) glad to read the outcome was so good from what could have been very catastrophic.
Send it back to Monster and tell them their **** sucks! they can't argue with a burned up plug like yours.PolkFest 2012, who's going>?
+1000
That is my worst fear not the gear it can be replaced, but a FIRE...Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
I once had a power surge come thru the house and it melted my surge protector right to the carpet and the only thing that didn't survive was my powered sub. Thankfully I was also home at the time I would have not wanted to see the outcome it I had not been. Glad to see that everything is ok.
MarkSig to be updated after dealing with the insurance company:(:(:( -
Wow, that one prong is burnt right off! I can't believe the breaker didn't trip sooner regardless of how bad of shape it may be in.
This gives me an idea for when I move into my house... replace all breakers! -
Hello
Just a followup, I talked to an electrician this morning and he came up with a great solution along with swapping out the breaker. I'm going to swap out some of the outlets, where theres three prong cords needed, with GFI's. That way if anything starts to even have a hint of shorting out it will trip the GFI also.
I did that with the outlet I had trouble with and then put in a UPS off of the GFI to run the Directv HD DVR.
Everything seems to be okay so far.....Testing
Testing
Testing -
I see the name MONSTER on it....there's your problem.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Yes, theres no more Monsters in the house:)Testing
Testing
Testing -
Hello
Just a followup, I talked to and electrician this morning and he came up with a great solution along with swapping out the breaker. I'm going to swap out some of the outlets, where theres three prong cords needed, with GFI's. That way if anything starts to even have a hint of shorting out it will trip the GFI also.
What is a GFI?"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
Ground Fault Interrupt
You more than likely have them as the plugs around sinks, bathtubs where a short could easily happen. I'm sure there is more technical stuff, but I don't know any of it.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
I hope you thanked someone for that blessing,, that plug looks nasty,, glad no one was hurt.:)JC approves....he told me so. (F-1 nut)
Those 3 prong to 2 prong adapters really are not to code and this is probably a case in point. The only way to go 3 prong to 2 within code is with a separate ground strapped to it or a GFCI outlet like the electrician recommended.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Whew! Glad you were able to avert disaster. Nice to hear everyones okay. Hope the gear is alright.
Pat.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring.
