M$ Excel Help please
avelanchefan
So I am pretty good with Excel, can do formulas, drop down boxes...blah, blah, blah.
Here is the issue, I want to make a one-to-one copy of a specific spreadsheet. This copy has to be made on a daily basis. The problem is when I do a copy and paste it does not create an exact replica, I have to go back and adjust row heights....etc.
When I tried the "paste special" feature, it created my cells horizontally not vertically.
Google is not coming up with any answers. Can someone please explain specifically on what I need to do.
Post edited by avelanchefan on
right click on your xl sheet name, click on move or copy and tick mark on create a copy, you should be fine.
Are you selecting the whole worksheet using that little empty square right between column A and row 1? That should take all formatting.
jacob.simpson wrote: »right click on your xl sheet name, click on move or copy and click mark on create a copy, you should be fine.
x2 That should work!
If you use the same formatting, but only change the data, you can also create a templet. When saving the document save it as a templet (.xlt)HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
jacob.simpson wrote: »right click on your xl sheet name, click on move or copy and tick mark on create a copy, you should be fine.
x2! works for me every month and preserves formatting."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
Yep....Jacob that worked perfectly. Really appreciate the help.
Thanks again for all the responses. -
Great, though i am not very good in xl little tricks we get to learn like this helps in furthering our knowledge. CP rocks
