Should I Try Rogue Magnum 66 Tube Preamp???
megasat16
megasat16 Posts: 3,521
edited August 2009 in Electronics
I am wondering what you tube aficionados think about the Magnum 66?
Is it a good pre to roll tubes? Anyone tried it before?
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Post edited by megasat16 on
    heiney9 Posts: 25,446
    edited August 2009
    DKG999 has one so hopefully he'll chime in. I've heard his on a couple occasions and was very impressed. If I decide to go with more than an entry level tube pre like I have now (Dared Sl2000A) this would be on my list as it's fairly priced and they come up FS quite often.
    So far I am very impressed with the Dared so it may be a while before I need a higher end tube pre.
  • megasat16
    edited August 2009
    Thanks H9! Appreciates for the input. :)
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited August 2009
    Have had a 66 Magnum for quite some time...good entry level pre that fits the bill for me.
    They come in two models,with a remote and no phono section...or with phono section and no remote.
    Takes the 12AU7,there are a world of tubes to choose from.
    Good used can usually be had for 550.-700.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2009
    I love my Rogue Magnum 66! It's a great pre, and responds well to both a good power cable and tube rolling. You'll want to get some good tube dampeners (I use Herbies) as that also helped. I've found that Sylvania Triple Mica Blackplates work really good with this pre. RCA Command and CBS Hytron are also good tubes for this pre. I just got some RCA cleartops that I have yet to try.
    I did replace the Rogue in my main system with an ARC SP16L pre. The ARC has everything I like about the Rogue, and just takes it all to a little higher level, with a wider and deeper soundstage. That's an opinion solely based on the integration in my current system.
    DKG999
  • megasat16
    edited August 2009
    Thanks dkg999 for a nice review on the Rogue 66. I think I'll just start off with it and move up the ladder at a later time. :)
  • dkg999
    dkg999 Posts: 5,647
    edited August 2009
    megasat16 wrote: »
    Quite frankly, you might not have to move up the ladder. It's that good.
    DKG999
  • megasat16
    edited August 2009
    Thanks Mike for chiming in. I am getting the one without remote and with Phono.
    I found one on Agon for $515 shipped so I pulled the trigger. It's silver and the seller said 9/10 so I hope it's worth it.
    dkg999 wrote: »
    Yeppie! I hope I am already at the top of the ladder with Magnum 66.
    Any recommendations on what Tubes to try for Tube Magic on the 66?
  • Mike Reeter
    edited August 2009
    That's a very good price for a 66 Magnum...I've owned that model previous to the one I have now;LSR
    I can't remember which tube the phono section accepted,but the linestage takes 12AU7's.
    Most will tell you to stay with NOS tubes only..."if" you can afford them,always been my downfall :D
    I've had good luck with re-issue tubes such as Amperex,Electro-Harmonix,Mullard,etc.
    Have fun with your new pre. It will take your rig to new heights.
  • megasat16
    edited August 2009
    The 66 Magnum has arrived. Time for testing...:) Pictures to follow up soon.
