My new lsi15s need sub?
I have been listening to my new lsi15s for a week now.At first I must say I did not like the sound at first:mad:.I am powering them with a onkyo 876 and rotel amp 500watts@4omhs.
But after I used the audyessey setup on the onkyo the sound improved alot real clear sound:).The only problem now is the bass its ok for music but I like lots of bass and for movies especially.
I have the lsi15s in a small room and know the sound would improve alot if I had them in a bigger room.Anyway I am sure a powered sub would work well with my lsi15s and thats where I need help to choose one my budget is around 400EURO any advice guys
Post edited by Nacken23 on
There are some good deals on ebay polkdirect for refurbished subs.
I have a psw1000 and it really rocks. -
Are your LSI's new? If so you should wait till you have about 100 hours on them. Speakers need a break time. Then decied if you still need a sub.
If you do decied to add a sub I suggest a Sunfire True sub.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
LSi15's should be good on their own for music. For home theater, a sub is definitely needed."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Have you broken in the speakers or are they still new?
My lsi 15s are new and i have used them less than 100 hours the bass is good but i want more for movies
I've heard they should have at least 400 hours on them to really even out the bass.
Thanks for your advice I didnt know that
I think its a general rule for many speakers give or take a few hundred hours. My RTia9s had muddy bass when I first received them. After a little break-in (500 hours) they really sounded much better. -
It depends on how much bass you like in your movies.
If you want impactful bass that can play as low and as loud as a movie soundtrack is meant to sound (or louder) you'll need a larger driver. Its physics!My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
I have 4 LSi15s in my HT/SACD multi-channel room. I never use a sub for music, and only rarely for movies. The only time a sub is necessary is if you want crazy bass for explosions, etc. I use a PSW1000 sub, and it is more than adequate for crazy bass.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
The problem I find is there is very little bass at low volumes and is a bit muffled so I want to correct this
Thats exactly it I want as you say crazy bass lol:D -
What source are you using?
Im looking at sunfire true subs as someone suggested I have my eye on SUNFIRE TSSJ8 TRUE SUBWOOFER SUPER JUNIOR JR 8" TS-SJ8
What do you guys think will this do the job was gonna buy off ebay but they dont ship to ireland -
SoundArtillery wrote: »What source are you using?
Im using my ps3 connected to the onkyo 876 through hdmi for LPCM audio and have all settings correct -
hmmm . . . I bet the bass will continue to tighten up over time, but I imagine you will still want some more quantity. Get a sub.
Yes - for home theater you need a subwoofer. What is the size of your room? (include any rooms that cannot be closed off from your home theater - need width, depth and height of the rooms)Mains.............Polk LSi15 (Cherry)
For HT you want a banging sub, SVS PB13U or PB12+ www.svsound.comShoot the jumper.....................BALLIN.............!!!!!
LSI-15's are great for music even without a sub, but for the full HT expeireince you'll need to add a sub......I have the DSW PRO 600 and it's very good for HT, but if you want to really shake the house look at the SVS.
My LSI's didn't really mellow out until I had about 60 to 100 hours on them.....I also found room placement to be more critical with the side firing woofer, so move them around and see if the sound changes.
Jimmy
BTW Welcome to Club Polk -
Im really want one of these SVS PB 12 plus subs now after checking it out and reading other reviews.It is bout 3 times my original budget like almost everything else I have bought for my home cinema but I know it would be more than worth it.Anyone know best site to buy one let me know:).
Im thinking though maybe this sub might be too much for my tiny room even though i like lots of bass.
What do you guys think? -
It's amazing how you always end up changing your mind and going with something that's way over your budget...lol...I've been afflicted with this problem a few times myself.
There's no such thing as overkill. You set the sub up to work in your individual room...you just won't have to crank it as much.
Best thing is, if you move into a new place with a bigger room, you'll be all set.:)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I think you just made up my mind for me and I will more than likely get it now.
Your right if i move somewhere with a bigger room I wont need a bigger sub. -
Now my mind is made up and im getting one but the only place i can find online to buy one is LSOUND and its 1100EUROS not including shipping to ireland:mad:
Is this a good price guys or can I get a better price? -
How about these cylinder subwoofers from SVS are these any good guys anyone own one?
Sherardp has one of the SVS's, as well as a few other members. Try a searchI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
I have 2 of the 25-31 + series subs. (the short cylinder's) They are just awesome. For home theater though - I wish I had the middle sized one. (just digs a little deeper)
I have both mine set for a 20hz tune and get a solid in-room response down to about 17hz.
I have a pair of SVS cylinder's. I rock the passive subs 20-39's. They don't make passive subs anymore but I can vouch for the quality. Make no mistake, they are huge- my cylinders are about 4 feet high and 18 inches diameter. Honestly the size is a plus since everyone comes in and is immediately impressed
A pair of subs will make you realize what home theater is all about. Put in Black Hawk down or Master and Commander on BR and people will be talking about your room for weeks.
P.S. If you are buying a pair, call and ask for a discount since you are buying two. They may not give it to you but will throw SOMETHING in for free.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
