DVD/VCR Combo issues
audiobliss
audiobliss Posts: 12,518
edited August 2009 in The Clubhouse
I'm trying to set-up a unit, but it's not playing nice with me. It's a Panasonic DMR-EZ485V, and it's anything but 'EZ'. All the setup menus and functions seem straight-forward enough, and they would be...if they'd work.
We're not running a cable box, we just get standard cable, so I have a coax running from the wall, to the unit's RF in, then RF out to the TV's RF in.
With the unit off, you can view TV just fine. With the unit on, but with the unit set to TV instead of VCR, you can view TV just fine. However, when you have the unit on and have the VCR selected (as in, using the unit's built-in RF tuner), the view on the TV is black & white and very speckled (like white noise), though you can fairly easily see the image of the TV show through all the distraction. When in the last scenario I change the channel on the unit (since I'm using the unit's RF tuner and have the TV set to 3), the channels do not change. The show that's playing through all the white noise is the same. And, when I turn off the unit and just use the TV's tuner to try and find that show (saw something that looked interesting that way earlier), I canNOT find it!
What in the world is going on here? I also checked it by using a video cable from the unit to the TV instead of a coax cable (no audio connected that way, just checking video), selected the right input on the TV, and got the exact same result.
Any ideas as to what's going on? What I did wrong? What's wrong with the unit?
ANY input would be greatly appreciated!!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • Marty913
    Marty913 Posts: 760
    edited August 2009
    Absolutely just a guess (or starting point) but I wonder whether the cable feed is digital versus analog. I realize the cable companies did not have to do anything related to the June cut-over to digital but most have been switching anyway just to get the bandwidth. A cable box solves the problem but straight from the wall into a pure analog VCR may be the problem. Just a guess.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • audiobliss
    edited August 2009
    Thanks for the input. I wonder if this has that issue covered: During setup it will automatically check and save channels, so it'll go through 135 channels, displaying analog, then go through all 135 again, displaying digital. So I'm assuming it's checking its entire range for analog and digital channels. Is that an invalid assumption?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Marty913
    Marty913 Posts: 760
    edited August 2009
    audiobliss wrote: »
    No, that's a valid assumption (I think). I assume the cable connected directly to the TV with channels scanned by the TV picks up everything. Cable connected directly to the VCR and scanned by the VCR doesn't seem to pick up anything. Connected via RCA composite to a spare TV input should eliminate any "channel 3/4" issues so the TV should be seeing exactly what the VCR is seeing (nothing or ghosts). I keep coming back to the VCR tuner / Cable Feed as the issue but have no real solution. Sorry.
    TT = Audio Technica
  • audiobliss
    edited August 2009
    At least we're both coming back to the same point. It helps to see someone else is coming to the same conclusion. Thanks for your input!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2009
    I haven't used a VCR in ages, but doesn't the TV have to be on Channel 3 (or 2) or something like that when used in that configuration? This probably isn't the answer you're looking for, but it's all I can think of.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2009
    You have an ATSC tuner in the Panasonic. That will NOT work with QAM.
    That's your problem.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    Those analog and digital tuners are for NTSC and ATSC channels, respectively.
    I set up one of these for my uncle and it does NOT work with cable service (coax) plugged directly into the unit.
  • audiobliss
    edited August 2009
    appadv - I really don't want to come across as too dense here, but could you give me a brief run down on NTSC, ATSC, and QAM? Sounds like you've solidly hit upon why it's not working for me, but I'm not understanding the compatibility here, or rather the lack thereof.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    NTSC is the tuner built into, to a large extent, almost every TV ever manufactured. It's for analog (over the air) TV reception.
    ATSC is a digital tuner similar to the one in those digital converter boxes you have seen going for $40-60 which allows you to tune in digital OTA signals. Its purpose is to receive OVER THE AIR broadcasts from local channels via an Antenna, not cable.
    QAM is what your cable provider uses to encrypt the signal - my TV has a QAM tuner and with the cable plugged DIRECTLY into the TV (no cable box), I can get regular digital channels.
    However, on a DVR with an NTSC/ATSC tuner, you get nothing when you plug the cable (coax) directly into the unit. Basically, you need a cable box.
  • edbert
    edbert Posts: 1,041
    edited August 2009
    It sounds like you could just hook the cable straight into the TV since that works and the TV will control what they watch on TV. Then just connect the VCR/DVD combo into the TV like you would a DVD player, purely for movie playback only. If you haven't tried a video tape or DVD, give it a shot to make sure that works fine and then move on. I think appadv is correct about the tuner issues running through the VCR, but you can always bypass that and send the signal to the VCR after it is processed by the TV's built-in tuner and you should get a clean signal that you can record if that is the desired end result.
    Good luck and let us know how it works!
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • audiobliss
    edited August 2009
    Thanks for the input, guys. I really appreciate it.
    I just checked the specifications in the back of the manual, and here's what I found:
    Television system:
         TV system:  Ntsc system, 525 lines, 60 fields
         Antenna reception input:
               Analog TV Channel:      2 ch to 69 ch
               Analog CATV Channel:  1 ch to 135 ch
               Digital TV Channel:       2 ch to 69 ch
               Digital CATV Channel:   1 ch to 135 ch
         RF converter output:
               Provide 3 ch or 4 ch
    So does that basically support everything you're saying? That the tuner can't decipher the information coming in on the coax cable?
    As I type this, excited that at least we seem to have discovered the reason for the issues, I think of a counter-point. All our TV's are at least 6 years old, some of them over 10 years old, and they can handle the input over the coax cables just fine. So that's leading me to believe we're not getting QAM, but still getting NTSC, which would mean there has to be a problem with the DVD/VCR's built-in tuner. No?
    Thanks again so much!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • edbert
    edbert Posts: 1,041
    edited August 2009
    Are these the specifications to the VCR? I am assuming so since that has been the focus of this thread, I just saw the TV system and thought I would clarify.
    If so, yes, it sounds like the cable signal and the signal the VCR can decode don't talk to each other, therefore you are getting static.
    You may check out THIS!!! It looks to be the same that you already have, but with the added digital TV tuner that you need without needing the cable box. At this point I would check with your cable provider to make sure that this would work.
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
  • audiobliss
    edited August 2009
    edbert wrote: »
    Thanks for the link, edbert. And yes, you're right, those are the specs for the tuner portion of the DVD/VCR unit.
    I just checked out our cable bill and looked our service up online, and we have basic, analog cable. So there's nothing digital going on here. There's no reason why the DVD/VCR's tuner wouldn't be able to decode it then, right? I think there's just something messed up with the unit's tuner. A loose connection or just flat out bad tuner. This unit was a display model, too.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    If you're getting just analog cable, that is NOT, and I repeat, not QAM.
    Analog cable should work with any NTSC tuner.
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    Television system:
    Yes, you are getting NTSC cable.
  • audiobliss
    edited August 2009
    Then the only conclusion I'm left to make is that the built-in tuner in the DVD/VCR unit is faulty, and the unit needs to be returned if possible.
    Thanks to all for your input and help with brainstorming! I really appreciate it!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Marty913
    Marty913 Posts: 760
    edited August 2009
    audiobliss,
    We've pretty much beat this to death but I thought I'd ask one more question. There are two types of analog cable transmission referred to as HRC and IRC. HRC is harmonically related carriers and IRC is incrementally related carriers. These are ways the cable company can modulate the video signal to improve the quality of their analog transmission. I've owned TV's and VCR's that required you to pick one of these before scanning your channels. Any chance you have such a selection in your setup menu ?
    TT = Audio Technica
  • Serendipity
    edited August 2009
    Marty913 wrote: »
    audiobliss,
    On my JVC HR-S7000U (ultra high end deck from the 80's) there was a switch for HRC and IRC cable. However, I am not sure if there is such a selection in audiobliss' unit.
  • audiobliss
    edited August 2009
    During the setup it will ask me to select if the input is from cable or antenna. That's the only option related to the channel scanning.
    Thanks again so much to everyone who contributed! It was of great help; I really appreciate it!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    Select "Cable". What happens?
  • audiobliss
    edited August 2009
    It will scan through all the channels, first in analog and then in digital, and then after forever report "No channels found".
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    What happens with an OTA antenna?
  • audiobliss
    edited August 2009
    appadv wrote: »
    Never connected an antenna to any TV's, nor this unit. I've selected the Antenna option while using the coax cable, but with the same result.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2009
    audiobliss wrote: »
    Sorry then, I'm not sure what else you could try.
