SVS Sub Info?
Serendipity
Serendipity Posts: 6,975
I've been trying to look at the new SVS Ultra-13 but I can't get to the page.
www.svsound.com
Anyone else having issues? I need a few specs on the Ultra 13 box and cylinder models.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    edited August 2009
    Ultra 13
    Exclusive SVS Ultra-13" high-output woofer
    750 watt BASH amp with room compensation
    Computer Assisted Design (CAD) enclosure
    Cast and chromed SVS badging
    Front-firing configuration with co-located vents
    Distinctive curved perforated magnetic grill
    "Stackable" form factor allows easy dual subs
    3.5" high-flow flared ports CURVE (TM) tuning
    Assembled in the Ohio SVS factory
    Choice of wood veneers, gloss or text. black
    Two grill choices, fabric or stylish steel
    Selectable Sealed, 20Hz, 15Hz or 10Hz modes
    +/- 3 dB 18 Hz-150 Hz (anechoic) in 20hz mode
    Size: 27” D x 20.5 " W x 22" H (w/o grill)
    Warranty: 3 year "bumper to bumper"
    Support: Free 7 day/week customer service
    Weight: 155 pounds
    PC 12 NSD
    Custom built SVS AL cone 12" NSD woofer
    Full-featured 325 watt BASH digital amp
    Built-in, flush-mount amp configuration
    Down-firing woofer with integrated base-plate
    Compliant floor mounts, low center of gravity
    Precision tuned high-flow ports
    Resonance free, protective top port grill
    16" high-strength, polymer wrapped enclosure
    CNC'd, laminated, 1.0" composite end-caps
    Extra heavy duty 8ft power cord
    Architectural-grade black fabric exterior
    Dims: 16" diameter, 35" tall, 59lbs.
    PC 12 PLUS
    New SVS designed/built Plus 12.4 woofer
    Exclusive down-firing cylinder design
    Proprietary 3" high-flow flared ports
    Resonance free, protective top grill
    525 watt BASH amp with PEQ
    Hand-built in the Ohio SVS factory
    Flush-mount amp configuration
    Extra heavy-duty detachable 8 foot power cord
    Selectable 25Hz, 20Hz, 16Hz or sealed modes
    Size: 40" tall, 16" diameter.
    Weight : 60 lbs
    PC 13 ULTRA
    SVS designed/built Ultra-13 woofer
    Down-firing woofer with integrated baseplate
    Exclusive 3.5" high-flow porting
    Variable tuning (20Hz native) with sealed mode
    Magnetically retained, removable grill
    CNC cut, braced, and hand assembled cabinet
    Size: Approx. 16” diameter x 46" tall
    Warranty: 3 year comprehensive coverage
    Weight: 90 pounds. (105lbs shipping weight)
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • thsmith
    thsmith Posts: 6,082
    edited August 2009
    yep, their site is acting wierd.
    I have the PB-13 and love it. set it, calibrated it and have not touched it since.
    Previousy I was trying all kinds of stuff with a ported big sub, 2 MBMs and a BFD and was never happy and always trying to squeeze more.
  • Willow
    Willow Posts: 11,240
    edited August 2009
    I was on the Canadian site today and noticed the weight of the PB-13 :eek:
    I'm still tempted myself to order one. I'll start by saving some cash first, but I will get one.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited August 2009
    I believe the site or the host was hacked. They are working on it now.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Ron Temple
    edited August 2009
    Willow wrote: »
    Yep, 155lbs kind of discourages you from a crawl test in a crowded room. However, the Ultra is svelte compared to some of the monsters that eD is building.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • danz1906
    danz1906 Posts: 5,144
    edited August 2009
    Great Sub, one of the best out there.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • hockeyboy
    hockeyboy Posts: 1,428
    edited August 2009
    Willow wrote: »
    Why just one? Two is like four times better.:D
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • FittyFieFo
    FittyFieFo Posts: 482
    edited August 2009
    I'm actually thinking on upgrading my subwoofer to the SVS PC 12 NSD--Thanks to Freddy (I should not talk to him at all haha)
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • FittyFieFo
    edited August 2009
    Website is back up!!
