Sound Comparison
restanim
restanim Posts: 227
edited August 2009 in Vintage Speakers
What would be the difference in sound between the SDA-1C and the SRS-3.1TL ?
polkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015
Post edited by restanim on
  • stubby
    stubby Posts: 723
    edited August 2009
    Probably not a huge difference. My 3.1's are modified (RDO and X-over) and I am very pleased with them. I used to own a pair of 1.2TL's and they compare nicely to them. They don't have the bottom end extension and the stage is a bit narrower. However, dynamic range is surprisingly similar and detail is a bit better. IMO, this is due to the single tweeter and the correspondingly less complicated X-over.
    If you can get them at a good price, grab 'em. Even a stock pair will have the SL3000 tweets. Thats worth something. I think they look a bit nicer as well, with the side wood trim.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
