Center Speaker Question & Piano Finish
I have a LSiC center speaker and always thought the sound was not crisp and it was difficult to understand the voices. Just by chance I decided to take the grills off of all the LSi's and to my amazement I found the white double layer foam protective sheet between the grill and the speakers! DUH!!! I won't embarrass myself by telling anybody how long it has been like that.
But I do have a question, it seems there is more sound coming from the right speaker than from the left. A touch confirms there is more vibration from the right speaker. Any ideas?
On reading a couple of posts regarding cleaning the piano finish I decided to try the 'Invisible Glass' product. I found they now have 'wipes' which is already damp with the product. That is what I got. Boy, it is amazing! I finished it off with light wipe or two with a microfiber cloth. Not a scratch to be found. Great info!
Thanks for the help!
Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Surround: Polk LSiF/X
Sub: Polk PSW10
Amps: Rotel RB 993 &
Parasound HCA-800 II
Pre/Pro:Anthem AVM-20
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
Post edited by LarryK on
The right speaker outputs the higher frequencies.TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3 -
Common Question. Here are some others with the same issue.
Long story short - you are fine, it is functioning as designed. Now that you have taken off the insulation between the grill and the speakers - put the grill back on, put it back in place and enjoy the sound....
Thanks for the info... as usual, great information!Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Sub: Polk PSW10
