How is a UPS supposed to be set up?
obieone
A little over a year ago, I built an HTPC, from an independent shop. Along with some of the parts, I bought an APC UPS unit(refurb.)
It was my understanding, that I should leave the UPS powered on all the time, and that it worked off a trickle charge.
Well, during the last 2 thunderstorms, it's not worked to keep the pc running?
It wasn't down for any significant time, just reset, like I would manually.
Is this thing NG, or am I doing something wrong?
Post edited by obieone on
I'm confused,, I have UPS's on my systems,,on some models there are 2 power "strips"..one for surge protection,and the other for surge/battery backup. Is that what you mean?JC approves....he told me so. (F-1 nut)
UPS batteries do have a 'fixed' life and need to be replaced.
In our companies datacenter, we get notices to replace RAID batteries(as built in power backup) quite often cuz some of the units are old.
You may want to check on APCs website what the battery life spec is for the UPS you bought.
Just a thought....
A good test is to pull the cord to feeds the UPS. On the other hand most UPS I ever seen have a battery indicator to show if it believes it's own batteries are ok. Not that a good indication would tell me the batteries are 100% if the UPS dies in under 5 mins up time running on batteries, but stating that the batteries are died then yes they are died.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I have an UPS set up on my home DVR and H/T PC, Basically what my UPS does is let my system shutdown in a normal fashion through software via the RS232 port. Each one of my UPS has a 12vdc 7A/H battery which will hold enough charge to let the PC(s) shut down normally...thats it. I have seen UPS that can run a PC for several hours, I just want my stuff to shut down normally in the event of a power outage. Hope this helps.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
george daniel wrote: »I'm confused,, I have UPS's on my systems,,on some models there are 2 power "strips"..one for surge protection,and the other for surge/battery backup. Is that what you mean?
DOH!:eek::o Thanks everyone. I'm all set.
(probably would have helped if I LOOKED at the damn thing, huh?):D
The battery/ surge protection outlets were hidden underneath an overhang on my desk, with a BIG yellow sticker, that said "HEY DUMBASS, over here!":pI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Just curious..what Ups are you using?Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
You didn't see the sticker? Incidentally, most UPS systems come with the battery unplugged and you're supposed to connect it and plug it to the wall for a few hours BEFORE hooking stuff up to it so it can charge with no load. Make sure you did that too!Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
I've always preferred Fedex._________________________________________________
Good,, we have all "been there,done that",, most just won't admit it,,I once thought that I could replace the battery with the thing plugged in.:eek:JC approves....he told me so. (F-1 nut) -
Actually some models do have "hot swappable" batteries.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Well,, my "hot" swapping days are over,, I drove past that exit some time ago.;)JC approves....he told me so. (F-1 nut)
george daniel wrote: »smarta$$Alea jacta est!
