Speaker settings for my amp
Hello All!
I have an old Sony STR-DE545 500W 5.1 Dolby Digital amp.
My speakers are as follows:
Fronts: Polk Monitor 60
Surrounds: Polk Monitor 50
Subwoofer: Polk PSW505B (Connected via LFE input)
What would be the best setting on my amp for these speakers?
My options are: Small or Large?
Thanks in advance!
Thanks in advance!
Post edited by viperrcr on
I would guess at small.
But at which settings does it sound best?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I just got the new speakers today and have not hooked them up yet, I haven't had a chance to compare the sound qualities.
Thanks for the suggestion!
My previous speakers were some 3-way giant old (Circa 1988) Kenwood KL-A700 speakers that had 17" subwoofers in them. Needless to say, I set those to LARGE! -
I would set all the speakers to small. That way you won't over drive them at higher volumes. It will be less stress on your amp.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Thanks, I'll give small a try.
