Tower rebuild input....
Systems
Systems Posts: 14,873
edited August 2009 in The Clubhouse
Hello
I had built a gaming rig for kid awhile back and one day he tried to turn it on and it was dead.....Okay should be the power supply, right?
Turned out I had to replace the power supply, motherboard, hard drive, and video card. Antec, Asus, and Western Digital replaced everything. MSI said the video card was out of warranty.
Do you think the power supply would do this much damage when it went?
Thanks for any replies....
Testing
Testing
Testing
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2009
    Yup.
    When a power supply goes it can easily send out bad power to every component in the system, killing them.
    You're lucky all that was replaced under warranty, since technically the power supply killed them all, and it's not the fault of those components that they died.
    Spend extra money on the power supply....some antecs are known for being unreliable.
    Main Surround -
  • Systems
    edited August 2009
    nguyendot wrote: »
    Yup.
    Yeah thats what I thought too, pretty lucky indeed. This is the first time I've had issues with an Antec power supply. I did put a Corsair in the last one I built though...
    Testing
    Testing
    Testing
  • nguyendot
    edited August 2009
    I'd rather have an Antec than a Corsair. I run a PC Power and Cooling right now - the most reliable out there. 750w and it's silent!
    Main Surround -
  • Systems
    edited August 2009
    nguyendot wrote: »
    Yeah thats right, I forgot about that brand........
    Testing
    Testing
    Testing
  • concealer404
    concealer404 Posts: 7,440
    edited August 2009
    Pc Power and Cooling is the ****!
  • Systems
    edited August 2009
    On another note, man, video cards these days.....You need a small nuclear power plant to run the things....
    Testing
    Testing
    Testing
  • nguyendot
    edited August 2009
    It depends on the application for the video card I suppose. Half my cards are passive (7300LE, 2400HD's) half active (Fire GL's, Quadros, and of course the old 3870HD and 8800GT).
    They take a LOT of power....
    Best power supply for the money in my opinion for these - pull the psu from a junked Dell XPS 700/710/720. They're all made by PC Power and Cooling (what do they offer cooling wise anyways?) and are either 750w or 1000w, and have the weight to back it up. They do have an additional 20 pin ATX power connector instead of the 4pin ATX 12V, but you can pull 2 yellow and 2 black from the 20 pin to creat the 4pin atx12v easily, and the extra 12V's on that 20pin connector are easily converted to 4pin molex for drives etc.
    These can be had for $20 on ebay....far cheaper than full retail PPC 750w psus going for 100+.
    Main Surround -
  • concealer404
    edited August 2009
    Lorthos wrote: »
    Ugh... don't get me started. I remember when i got my first REAL video card, an Asus V9999 Gamer Edition. Essentially an old GeForce 6800 non-ultra on an Ultra PCB with the faster Ultra memory. Once i unlocked the remaining 4 pipes, my PSU was not a happy camper.
    I thought that card was ridiculous. And probably like you, i took a look around what's offered these days. Holy crap.
  • nguyendot
    edited August 2009
    I have two 7950GTX's sitting at home... talk about power hungry. Those sit next to the FireGL V7100 (i think?) unused....next to the quadro thats essentially a 7900GTX...but 20x the price.
    Main Surround -
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2009
    We've had many Antec power supply failures here, usually takes out other componnents as well. They are usually still uner warranty, but we don't bother to exchange them, no more Antecs for us.
  • Marty913
    Marty913 Posts: 760
    edited August 2009
    Lorthos wrote: »
    I've probably worked on a few thousand computers over the last couple decades and it does seem that the Antec crop of the last 6-7 years has had a lot more problems than the Antec of the old days. I would have to agree that PC Power and Cooling is putting out some good stuff but I would disagree with the comment about Corsair. I've been running a Corsair for 2 years 7 X 24 and its been great. Had good luck with Enermax also.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • John30_30
    John30_30 Posts: 1,024
    edited August 2009
    Lorthos wrote: »
    Hello
    It's possible, but I'd lean more at it being a surge. Kid plugs directly into the wall socket, lightning or a surge a few days later, bang. Gone.
    If it happens again using a new P.S., you've been warned.
    nguyendot wrote: »
    Nice Pro-Tip.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited August 2009
    nguyendot wrote: »
    Been running my 610 watt PC power and cooling since august 2005; rock solid.
  • unc2701
    unc2701 Posts: 3,587
    edited August 2009
    I had an Antec go on me, too- and this wasn't on a high-power rig. Didn't fry anything else, but it was still a major annoyance.
    Backburner:Krell KAV-300i
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2009
    Im running an Antec right now in my new rig and it performs well. Hope I never have a problem with it. I also run a GTX275 video card and it requires two power inputs to run so I can understand the need for big power supply. My new rig consist of Antec 902 case, gigabyte 790x-ud4p mobo, 500 gb WD HD, dual Lite On DVD+RW drives, GTX275 video, AMD Phenom II X4 920 2.8 ghz CPU overclocked @ 3.5 ghz, Xigmatek Dark Knight CPU HSF, 4gb Kingston Hyper X DDR2. Of all the components in this new rig, I think the cooler and fan impresses me the most.
    billbillw Posts: 7,541
    edited August 2009
    Your quite the whiper-snapper if that's your first gaming card!
    Shoot, my first was a TNT Ultra2, the bomb at the time! It had a whole 32MB of RAM! Since then, Radeon 9800pro, GeForce 5900, ATI x800AIW, x1950pro, and now I have a 9600GSO w/768MB of DDR3
  • Sherardp
    edited August 2009
    Its funny how fast the technology has progressed. I'm sure allot of you remember when 512mb ram was considered allot in a setup. I remember my old AMD cartridge processors. Funny. My 1st setup AMD K7 Slot A 500mhz CPU. When I finally reached 1gig, oh the excitement.
    edited August 2009
    Sherardp wrote: »
    Yep, a cartridge Athlon 600mhz was the first that I built too. That was some ridiculously unstable crap back then. Driver support was terrible! I was on a budget at that time and could only afford 256mb (which was more than $100 a stick back then). I spent almost $200 for a 20GB hard-drive at that time also.
  • nadams
    nadams Posts: 5,877
    edited August 2009
    Antec's cheaper line had issues with bad capacitors for a while. They seem to be okay now, and most of the ones you get back in warranty are actually made by Delta. I had three go in the life of one PC that I built.
    As for old reminiscing about computers... :D I'm only 23, but I remember our first PC being a 486/66 dx2 w/ 4mb RAM and a 540mb HD. No 3d processing, and a 1x CDROM drive.
    The first machine that was actually mine was a Socket 7 AMD K6-II 450mhz with 128mb PC-100 ram and a VooDoo Banshee 16mb card. I played all my favorite games like Doom2 and Rise of the Triad on a MASSIVE 15" CRT monitor. I think I had a 1.2 gb HD at the time. Next step for Processor was an AMD Athlon 800mhz (I skipped the slot procs, this was a socket), then to a 2100+, and then to a Pentium 4 3.2ghz, which is where I'm at now.
    Ludicrous gibs!
  • concealer404
    edited August 2009
    billbillw wrote: »
    Well.... my first crazy high end (at the time) card.
    First real one i remember was a 9600xt 256mb edition, and that wasn't bad. Then i went to a PNY 5900se that i modded, it held an overclock like no other. Was good for 54000 on Aquamark3 paired with a Socket A cpu.
    Then i got the V9999 GE. Monster of a card, i loved that thing. I might even still have it around somewhere.
    But yeah.... i'm only 23. :)
  • sucks2beme
    sucks2beme Posts: 5,683
    edited August 2009
    Dare I say my first PC build was a 6 mhz 286 clone?
    Not the first pc, though. Remember cassette data storage?
  • renowilliams
    renowilliams Posts: 920
    edited August 2009
    Sherardp wrote: »
    And lets not forget the lights..... has the Vegas strip moved into your case....lol
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • Sherardp
    edited August 2009
    Oh yeah, city of dreams. Good thing with this one, I can turn them on or off.
