Where can I find a 6.5" Speaker Box?
joedavenport
joedavenport Posts: 3
edited May 2011 in Speakers
I would like to enclose a set of MM6 6.5" components. Where can I buy a speaker box?
I don't really have any tools and I am moving soon so I don't want build one myself. Thanks.
Post edited by joedavenport on
  • rs159
    rs159 Posts: 1,027
    edited March 2003
    Interesting idea, I think car speakers are made with the car's cabin gain in mind but I'd like to hear from someone who knows if that would work.
  • gacole2000
    gacole2000 Posts: 255
    edited March 2003
    try this:
    http://partsexpress.com/
    Good Luck- Greg
    AVR: Yamaha RX-V661
    DVD: Yamaha DV-C6480
    BR: Samsung 1600
    Mains: Polk RT55 (bi-amped)
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
    Projector: Optoma HD70 w/ 106" Elite Screen
    Power: Panamax MAX 5100
    Remote: Harmony One
  • rs159
    rs159 Posts: 1,027
    edited March 2003
    The only problem I could see is the Xover is in one piece so it can't be built in to the box. Other than that I think it would look pretty slick. Nice industrial/futuristic design without being to gaudy. I can see it now...
    (sorry 'bout the pic, the comp I'm on doesn't have Photoshop)
  • joedavenport
    edited March 2003
    Good suggestion with Parts Express but they only had a 6" box.
    Nice picture, but I already have a location for the tweeter. This is going in a Wrangler, that's why I need the box.
  • gacole2000
    edited March 2003
    Did you try crutchfield?
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • joedavenport
    edited March 2003
    yea, I looked there too. :(
  • Beachsideaudio
    Beachsideaudio Posts: 1
    edited May 2011
    good morning:
    you can make your speaker boxes but its depending on if its marine , bike or inside a car. I use marine grade plywood water proof them then cover them to match the bike. Inside a car I would use mdf ( better for the sound of the speaker).
    I am working on building some fiberglass speaker pods but I am still on a learning curve. LOL
    I am restricted on size so I can't use the speker box programs they have that would allow you to get the correct speaker flat response.
    Good luck with it. I am new to the site. love the polk quality I just spent $9300. installing two great systems in both my new vehicles. quality !
    Thanks Polk!:biggrin:
    heiney9 Posts: 25,430
    edited May 2011
    Really!!! An 8 year old thread.....you are responding to an 8 year old thread. Did it take that long to formulate an answer.
    WTF
